Statistics graph card
The statistics graph card allows you to display a graph of statistics data for each of the entities listed.
Screenshot of the statistics graph card for power entities Screenshot of the statistics graph card with none metered entities and `chart_type` `line`.
Screenshot of the statistics graph card for energy entities Screenshot of the statistics graph card with a metered entity and `chart_type` `bar`.
Statistics are gathered every 5 minutes and also hourly for sensors that support it. The 5-minute statistics will be retained for the duration set in the recorder configuration, and hourly statistics will be retained indefinitely. It will either keep the min, max, and mean of a sensor’s value for a specific hour or the sum for a metered entity.
If your sensor doesn’t work with statistics, check this.
To add the statistics graph card to your user interface:
  1. In the top right of the screen, select the edit button.
    • If this is your first time editing a dashboard, the Edit dashboard dialog appears.
      • By editing the dashboard, you are taking over control of this dashboard.
      • This means that it is no longer automatically updated when new dashboard elements become available.
      • Once you’ve taken control, you can’t get this specific dashboard back to update automatically. However, you can create a new default dashboard.
      • To continue, in the dialog, select the three dots menu, then select Take control.
  2. Add a card and customize actions and features to your dashboard.
All options for this card can be configured via the user interface.
YAML configuration
type string Required
statistics-graph
entities list Required
A list of entity IDs or entity objects (see below), or an external statistic id
days_to_show integer (Optional, default: 30)
Days to show in graph. Minimum is 1 day.
chart_type string (Optional)
If the graph should be rendered as a bar or a line chart.
stat_types list (Optional)
The statistics types to render. min, max, mean, sum, state, change
title string (Optional)
The card title.
period string (Optional)
The period of the rendered graph. 5minute, hour, day, week or month. If energy_date_selection is true, and period is not defined, the chart period will auto-select between month/day/hour based on the selected date range.
hide_legend boolean (Optional, default: false)
If true, the legend will be hidden.
logarithmic_scale boolean (Optional, default: false)
If true, numerical values on the Y-axis will be displayed with a logarithmic scale.
min_y_axis float (Optional)
Lower bound for the Y-axis range.
max_y_axis float (Optional)
Upper bound for the Y-axis range.
fit_y_data boolean (Optional, default: false)
If true, configured Y-axis bounds would automatically extend (but not shrink) to fit the data.
expand_legend boolean (Optional, default: false)
If true, the legend will show all items initially
energy_date_selection boolean (Optional, default: false)
If true, chart date range will follow the date selected on an energy-date-selection card on the same view, similar to energy cards.
collection_key string (Optional)
If using energy_date_selection, you can set a custom key to match the optional key of an energy-date-selection card. This is not typically required, but can be useful if multiple date selection cards are used on the same view.
Options for entities
If you define entities as objects instead of strings, you can add more customization and configuration:
entity string Required
Entity ID.
name string (Optional)
Overwrites friendly name.
Example
type: statistics-graph
title: 'My Graph'
entities:
  - sensor.outside_temperature
  - entity: sensor.inside_temperature
