Plant status card
The plant status card is for all the lovely botanists out there.
Screenshot of the plant status card Screenshot of the plant status card.
To add the plant status card to your user interface:
  1. In the top right of the screen, select the edit button.
    • If this is your first time editing a dashboard, the Edit dashboard dialog appears.
      • By editing the dashboard, you are taking over control of this dashboard.
      • This means that it is no longer automatically updated when new dashboard elements become available.
      • Once you’ve taken control, you can’t get this specific dashboard back to update automatically. However, you can create a new default dashboard.
      • To continue, in the dialog, select the three dots menu, then select Take control.
  2. Add a card to your dashboard.
All options for this card can be configured via the user interface.
YAML configuration
type string Required
plant-status
entity string Required
Entity ID of plant domain.
name string (Optional, default: Entity name)
Overwrites friendly name.
theme string (Optional)
Override the used theme for this card with any loaded theme. For more information about themes, see the frontend documentation.
Example
Basic example:
type: plant-status
entity: plant.bonsai
