Picture elements card
The picture elements card is one of the most versatile types of cards.
A functional floorplan powered by picture elements.
The cards allow you to position icons or text and even buttons on an image based on coordinates. Imagine floor plan, imagine picture-glance with no restrictions!
To add the picture elements card to your user interface:
- In the top right of the screen, select the edit
button. - If this is your first time editing a dashboard, the Edit dashboard dialog appears.
- By editing the dashboard, you are taking over control of this dashboard.
- This means that it is no longer automatically updated when new dashboard elements become available.
- Once you’ve taken control, you can’t get this specific dashboard back to update automatically. However, you can create a new default dashboard.
- To continue, in the dialog, select the three dots
menu, then select Take control.
- Add a card and customize actions and features to your dashboard.
YAML configuration
The URL of an image.
To use a locally hosted image, see Hosting.
Override the used theme for this card with any loaded theme. For more information about themes, see the frontend documentation.
This image is used when the dark mode is activated and no state image is set.
Elements
Elements are the active components (icons, badges, buttons, text, etc.) that overlay the image.
There are several different element types that can be added to a Picture Elements card:
State badge
This element creates a badge representing the state of an entity.
Position and style the element using CSS.
position: absolute, transform: translate(-50%, -50%)
Action taken on card tap. See action documentation.
Action taken on card tap and hold. See action documentation.
Action taken on card double tap. See action documentation.
State icon
This element represents an entity state using an icon.
Set to true
to have icons colored when entity is active.
State label
This element represents an entity’s state via text.
If present, the corresponding attribute will be shown, instead of the entity’s state.
Perform action button
This entity creates a button (with arbitrary text) that can be used to perform an action.
Icon element
This element creates a static icon that is not linked to the state of an entity.
Image element
This creates an image element that overlays the background image.
Entity to use for state_image
and state_filter
and also target for actions.
Default: grayscale(100%)
when entity state is off
. Set to none
to remove this.
Forces the height of the image to be a ratio of the width. Valid formats: Height percentage value (23%
) or ratio expressed with colon or “x” separator (16:9
or 16x9
). For a ratio, the second element can be omitted and will default to “1” (1.78
equals 1.78:1
Conditional element
Much like the Conditional card, this element will let you show its sub-elements based on entity states.
List of entity IDs and matching states.
One or more elements of any of the listed types to show when conditions are met. See below for an example.
Custom elements
The process for creating and referencing custom elements is the same as for custom cards. Please see the developer documentation for more information.
Notes on element attributes
How to use the style object
Position and style your elements using CSStransform: none
to disable this behavior.
How to use state_image
Specify a different image to display based on the state of the entity.
How to use state_filter
Specify different CSS filters
How to use click-and-hold
If the option hold_action
is specified, that action will be performed when the entity is clicked and held for half a second or more.
