Horizontal stack card
The horizontal stack card allows you to stack together multiple cards, so they always sit next to each other in the space of one column.
To add the horizontal stack card to your user interface:
  1. In the top right of the screen, select the edit button.
    • If this is your first time editing a dashboard, the Edit dashboard dialog appears.
      • By editing the dashboard, you are taking over control of this dashboard.
      • This means that it is no longer automatically updated when new dashboard elements become available.
      • Once you’ve taken control, you can’t get this specific dashboard back to update automatically. However, you can create a new default dashboard.
      • To continue, in the dialog, select the three dots menu, then select Take control.
  2. Add a card and customize actions and features to your dashboard.
YAML configuration
type string Required
horizontal-stack
title string (Optional)
Title of stack.
cards list Required
List of cards.
Example
type: horizontal-stack
title: Lights
cards:
  - type: picture-entity
    image: /local/bed_1.png
    entity: light.ceiling_lights
    image: /local/bed_2.png
    entity: light.bed_light
YAML
Two picture cards in a horizontal stack card Two picture cards in a horizontal stack card.
