History graph card
The history graph card allows you to display a graph for each of up to eight entities.
Screenshot of the history graph card for entities without a unit_of_measurement Screenshot of the history graph card, when the sensor has no `unit_of_measurement` defined.
Screenshot of the history graph card for entities with a unit_of_measurement Screenshot of the history graph card, when the sensor has a `unit_of_measurement` defined.
To add the history graph card to your user interface:
  1. In the top right of the screen, select the edit button.
    • If this is your first time editing a dashboard, the Edit dashboard dialog appears.
      • By editing the dashboard, you are taking over control of this dashboard.
      • This means that it is no longer automatically updated when new dashboard elements become available.
      • Once you’ve taken control, you can’t get this specific dashboard back to update automatically. However, you can create a new default dashboard.
      • To continue, in the dialog, select the three dots menu, then select Take control.
  2. Add a card and customize actions and features to your dashboard.
Only the y-axis and logarithmic scale settings can be configured via the user interface. To configure the other options for this card, you need to edit the YAML configuration.
YAML configuration
type string Required
history-graph
entities list Required
A list of entity IDs or entity objects, see below.
hours_to_show integer (Optional, default: 24)
Hours to show in graph. Minimum is 1 hour. Big values can result in delayed rendering, especially if the selected entities have a lot of state changes.
title string (Optional)
The card title.
show_names boolean (Optional, default: true)
If false, no entity names are shown in the card.
logarithmic_scale boolean (Optional, default: false)
If true, numerical values on the Y-axis will be displayed with a logarithmic scale.
min_y_axis float (Optional)
Lower bound for the Y-axis range.
max_y_axis float (Optional)
Upper bound for the Y-axis range.
fit_y_data boolean (Optional, default: false)
If true, configured Y-axis bounds would automatically extend (but not shrink) to fit the data.
expand_legend boolean (Optional, default: false)
If true, the legend will show all items initially
Options for entities
If you define entities as objects instead of strings, you can add more customization and configuration:
entity string Required
Entity ID.
name string (Optional)
Overwrites friendly name.
Examples
type: history-graph
title: 'My Graph'
entities:
  - sensor.outside_temperature
  - entity: media_player.lounge_room
Or with longer time frame, and multiple entities (as long as they share the same unit_of_measurement) in one graph:
type: history-graph
title: "Temperatures in the last 48 hours"
hours_to_show: 48
entities:
  - entity: sensor.lounge_temperature
  - entity: sensor.attic_temperature
