Alarm panel card
The alarm panel card allows you to arm and disarm your alarm control panel integrationsIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more].
Screenshot of the alarm panel card Screenshot of the alarm panel card.
To add the alarm panel card to your user interface:
  1. In the top right of the screen, select the edit button.
    • If this is your first time editing a dashboard, the Edit dashboard dialog appears.
      • By editing the dashboard, you are taking over control of this dashboard.
      • This means that it is no longer automatically updated when new dashboard elements become available.
      • Once you’ve taken control, you can’t get this specific dashboard back to update automatically. However, you can create a new default dashboard.
      • To continue, in the dialog, select the three dots menu, then select Take control.
  2. Add a card and customize actions and features to your dashboard.
All options for this card can be configured via the user interface.
YAML configuration
type string Required
alarm-panel
entity string Required
Entity ID of alarm_control_panel domain.
name string (Optional)
Overwrites friendly name.
Default:
Current state of the alarm entity.
states list (Optional)
Controls which states to have available.
Default:
arm_home, arm_away
arm_home
Arm Home
arm_away
Arm Away
arm_night
Arm Night
arm_custom_bypass
Arm Custom Bypass
theme string (Optional)
Override the used theme for this card with any loaded theme. For more information about themes, see the frontend documentation.
Examples
Title example:
type: alarm-panel
entity: alarm_control_panel.alarm
YAML
Define the state list:
type: alarm-panel
states:
  - arm_home
  - arm_away
  - arm_night
  - armed_custom_bypass
YAML
