0.73.2 - Security Incident
Today we are releasing 0.73.2 to fix a security incident. We’ve discovered that 9 months ago, with the release of Home Assistant 0.56, we misconfigured the SSL context that aiohttp used (PR
A man in the middle attack is when an attacker is able to inject itself between you and the server you’re communicating with, allowing it to read and alter the communication. The odds of this happening at home is very rare, yet we wanted to be transparent about this incident.
After research, the following integrations have been impacted. Although the odds are extremely small, we still suggest that if you use any of these integrations, to create new API keys or change your password.
- climate.sensibo
- cloud (only short lived tokens impacted)
- device_tracker.automatic
- duckdns
- freedns
- google_assistant (manual setup)
- google_domains
- homematicip_cloud
- image_processing.openalpr_cloud
- microsoft_face
- namecheapdns
- no_ip
- notify.flock
- notify.prowl
- rest_command
- scene.lifx_cloud
- switch.rest
- telegram_bot.polling
- tts.voicerss
Also impacted, but integrations are read only:
- sensor.airvisual
- sensor.ebox
- sensor.fido
- sensor.foobot
- sensor.hydroquebec
- sensor.startca
- sensor.teksavvy
- sensor.thethingsnetwork
- sensor.tibber
- sensor.waqi
If you are running Home Assistant on a system with Python 3.4, we’ve created a new release 0.64.4b0 with the patch applied. We have made it available as a beta. To install the pre-release run python3 -m pip install homeassistant==0.64.4b0
For complete transparency, the following two sets of integrations also used aiohttp to send or retrieve data. However, they either did not transmit authentication or only communicated with local devices and services.
Affected, but not transmitting authentication:
- sensor.buienradar
- sensor.citybikes
- sensor.comed_hourly_pricing
- sensor.luftdaten
- sensor.pollen
- sensor.sochain
- sensor.swiss_public_transport
- sensor.viaggiatreno
- sensor.wunderground
- sensor.yr
- weather.ipma
- tts.google
- tts.yandextts
- updater
Local, so cannot be impacted:
- android_ip_webcam
- apple_tv
- camera.amcrest
- camera.doorbird
- camera.familyhub
- camera.generic
- camera.mjpeg
- camera.proxy
- camera.synology
- deconz
- device_tracker.upc_connect
- hassio
- hue
- media_player.bluesound
- media_player.epson
- media_player.kodi
- media_player.squeezebox
- media_player.volumio
- notify.kodi
- qwikswitch
- rainmachine
- scene.hunterdouglas_powerview
- sensor.netdata
- sensor.pi_hole
- sensor.sma
- sensor.worxlandroid
- spc
- tts.marytts
