0.36: ISS, USPS, Image processing, Insteon
Welcome to 2017 and 0.36. We are proud to announce the first release for this year. While we are still migrating parts to async but 0.36 is focusing on new features and a lot of bug fixes.
Packages
Packages are providing a new way to organize different component’s configuration parts together. With packages we offer the option to include different components or parts of configuration using any of the !include
directives.
InfluxDB export
The InfluxDB component was causing problems in a wide variety of use cases. @titilambert
International Space Station (ISS)
No, unfortunately we are not going to space. The iss
sensor is tracking the position of the International Space Station and gives you some details.
Insteon local
The support for Insteon was removed due to issues a while ago. With the insteon_local
component support for Insteon is back and let one work locally with an Insteon setup.
Image processing
The new image processing component currently works with number plates. But this could level the way to integrate feature like facial recognition, motion detection, or gestures control.
Sensor: Support for HydroQuebec (@titilambert
Sensor: Tracking the ISS (@HydrelioxGitHub
Sensor: USPS deliveries tracking (@happyleavesaoc
Device tracker: New ping-based tracker (@michaelarnauts
Switch: BeagleBone Black GPIO are supported now (@MatoKafkac
Switch: Support for customised Kankun SP3 Wifi switches (@webworxshop
Insteon local: Local insteon support(@craigjmidwinter
Sensor: Show details of the Dublin RTPI information (@ttroy50
Light: Zengge Bluetooth bulbs (@mjg59
Fan: Wink support for fans (@w1ll1am23
Device tracker: New TrackR device tracker support (@w1ll1am23
Device tracker: Support for Xiaomi router (@RiRomain
Sensor: New SMA Solar Webconnect sensor (@kellerza
Notify: Lannouncer TTS support (@michaelarnauts
Image processing: Support for Image processing (@pvizeli
Weather: Australian BOM (Bureau of Meteorology) support (@Zac-HD
Notify: Support for MySensors notifications (@MartinHjelmare
TTS: New Yandex SpeechKit TTS integration (@lupin-de-mid
Notify: Facebook Messenger support (@gopalkildoliya
Sensor - sonarr: Add
urlbase
to Sonarr (@quadportnick) -
Switch - broadlink: Support for SP devices (@Danielhiversen
Homematic: Support for HMIP-PSM or HMWIOSwitch (@danielperna84
, @pvizeli ) -
Light - flux: Ledenet protocol support by Flux LED (@bah2830
Device tracker: Support for longer intervals (@partofthething
ISY994: Weather sensors added (@rmkraus
InfluxDB: Improvements to avoid issues with storing details (@titilambert
Light - Yeelight: Auto discovery support and color temperature feature for Yeelight (@jjensn
Media player - SqueezeBox: Switch to JSON-RPC (@dasos
Scripts: Support for
last_triggered
(@Danielhiversen) -
Media player: Support for
SUPPORT_PLAY
flag (@armills) -
Docker:
ffmpeg
is now included by default (@colinodell) -
Minor and not so minor features and bug fixes by @balloob
, @pvizeli , @fabaff , @mezz64 , @andrey-git , @aequitas , @abmantis , @turbokongen , @jabesq , @michaelarnauts , @kellerza , @titilambert , @btorresgil , @henworth , @armills , @mjg59 , @Giannie , @n8henrie , @magicus , @florianholzapfel , @MrMep , @bah2830 , @happyleavesaoc , @lwis , @glance- , @markferry , and @nikdoof .
Release 0.36.1 - January 17
- Fix load_yaml default value (@balloob
) - Fix discovery of flux_led (@Danielhiversen
) - Fix Python Nest dependency re-installation (@Danielhiversen
) - Make USPS to use absolute path to save cookie (@tchellomello
) - Fix UPC_connect cookies (@pvizeli
) - Fix Eq3bt import issues (@rytilahti
) - Fix Bluetooth and Volvo trackers (@pvizeli
) - Fix lannouncer notify platform (@mKeRix
APNS service was moved to the
notify
domain. Usenotify.apns_NOTIFIER_NAME
instead ofapns.NOTIFIER_NAME
InfluxDB component has a new schema to store values in the InfluxDB database. You may require to run the
influxdb_migrator
script. You have to note:- There will not be any tags/fields named time anymore.
- All numeric fields (int/float/bool) will be stored as float inside influx db.
- All string fields corresponding to state attributes will be renamed as FIELDNAME_str, where FIELDNAME is the state attribute, to avoid type conflicts.
- All string fields corresponding to a state will be renamed as state (former value).
- Fields named value will always be stored as float.
- Fields named state will always be stored as string.
- TTS cache files use now the language abbreviation as part of the name. If you want to use the cache, it need to be renamed or cleared, new created. E. g.
HASH_PLATFORM.xxx
->HASH_LANG_PLATFORM.xxx
…don’t hesitate to use our Forum or join us for a little chat
Reporting Issues
