0.33: New Calendar component, Wink thermostats and Cisco IOS
For this release we put a lot of focus on finishing our async upgrade and fix a bunch of bugs in the process.
But a new release wouldn’t be awesome if it didn’t had some new goodies and this release is no different. This release includes a new calendar component by @mnestor
Changes
- New calendar component including Google support (@mnestor
) - Final core upgrade for async (@pvizeli
Neato refactor + sensor support (@turbokongen
) - Device Tracker: Swisscom Internet-Box now supported (@betrisey
) - Device Tracker - Locative: Map support added (@danijelst
Emulated Hue will now sent request info as variables to scripts that get called (@bah2830
) - Wink: Thermostats are now supported (@w1ll1am23
) - Light: New MQTT template platform for custom communication (@Diaoul
Wake on Lan switch can now configure a custom OFF script (@Chris-V
) - Device Tracker: Cisco IOS now supported (@fbradyirl
) - Sensor: Support for PVOutput snesor (@fabaff
) - Sensor: Show count of connected clients to the API stream (@balloob
) - Fix platforms from doing I/O in the event loop (@balloob
, @pvizeli , @lwis , @kellerza ) - Switch - TP Link: Add daily consumption (@gonzalezcalleja
) - Templates: Add new
strptime
template function for parsing times (@lwis) -
HTTP component: Fix X-Forwarded-For parsing (@mweinelt
) - Switch - Command Line: Use configured object_id for entity IDs (@n8henrie
MQTT now supports birth and last will messages (@bestlibre
) - Better handling of accented characters in slugify (@magicus
) - Alarm Control Panel - Envisalink: Add new keypress service (@jnimmo
) - Light - Hue: Add service to activate scenes defined in Hue app (@sdague
Release 0.33.1 - November 20
- Fix Z-Wave lights (@turbokongen
Release 0.33.2 - November 22
- Fix Device Tracker init (@pvizeli
) - Fix Discovery init (@pvizeli
) - Fix TP-Link switch (@mweinelt
) - Fix Zwave light naming & configurable refresh (@jchapple
) - Neato fixes (@turbokongen
) - Fix ‘Unknown’ status for Nest Protect devices (@Khabi
Release 0.33.3 - November 23
- Update Yr.no entities every hour (@kellerza
) - Bump Netdisco to 0.7.7 (fixes discovery on Synology)
- Fix discovery race condition (most obvious in Wemo) (@balloob
Release 0.33.4 - November 24
- Set executor pool size to 10 (as intended) (@pvizeli
This should fix occasional performance problems that some people have reported.
- We have included a fix that impacts how we generate entity ids. This only impacts devices with accented characters. Instead of being stripped out, they are now replaced with the non-accented version. So now
Tèst Mörê
will becometest_more
instead oftst_mr
. - Command line switches will now use the specified object ID for their entity ID instead of basing it off the name.
Reporting issues
