Yale Smart Living
The Yale Smart Living integrationIntegrations connect and integrate Home Assistant with your devices, services, and more.
[Learn more] provides connectivity with the Yale Smart Alarm systems and Smart Hub through Yale’s API.
- Alarm
- Binary sensor
- Button
- Lock
To add the Yale Smart Living integration to your Home Assistant instance, use this My button:
From the list, select Yale Smart Living.
Alarm control panel
Services provided are armed_away
, armed_home
, and disarmed
No code is required to operate the alarm.
Binary sensors
Provides support for contact sensors for doors showing if door is open or closed.
Button
Provides support for pressing the panic button to trigger the alarm. Be careful as another press does not reset/turn off panic mode.
Lock
The lock platform requires a code for unlocking but no code for locking.
The integrationIntegrations connect and integrate Home Assistant with your devices, services, and more.
[Learn more] can be configured to provide a default code that is used if no code is supplied and the number of digits required.
