IBM Watson TTS
The watson_tts text-to-speech integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] that works with IBM Watson Cloud to create the spoken output. Watson is a paid service via IBM Cloud but there is a decent free tier which offers 10000 free characters every month.
Setup
For supported formats and voices please go to IBM Cloud About section.
To get started please read the Getting started tutorial.
To configure Watson TTS, add the following lines to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file, restart Home Assistant to apply the changes. To view the changes, go to Settings > Devices & services > Entities.
tts:
  - platform: watson_tts
    watson_apikey: YOUR_GENERATED_APIKEY
You can get these tokens after you generated the credentials on the IBM Cloud console:
watson_url string (Optional)
The endpoint to which the service will connect.
Default:
https://api.us-south.text-to-speech.watson.cloud.ibm.com
watson_apikey string Required
Your secret apikey generated on the IBM Cloud admin console.
voice string (Optional, default: en-US_AllisonV3Voice)
Voice name to be used.
output_format string (Optional, default: audio/mp3)
Override the default output format. Supported formats: audio/flac, audio/mp3, audio/mpeg, audio/ogg, audio/ogg;codecs=opus, audio/ogg;codecs=vorbis, audio/wav
Usage
Say to all media_player device entities:
- service: tts.watson_tts_say
    message: "Hello from Watson"
or
    message: >
      <speak>
          Hello from Watson
      </speak>
Say to the media_player.living_room device entity:
    entity_id: media_player.living_room
    message: >
      <speak>
          Hello from Watson
      </speak>
Say with break:
    message: >
      <speak>
          Hello from
          <break time=".9s" />
          Watson
      </speak>
Optionally, specify a voice for the message:
  options:
    voice: en-US_EmilyV3Voice
