Vodafone Station
The Vodafone Station integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control your Vodafone Station based router.
The integration provides information about your internet connection and the connected devices.
Supported devices
The integration supports only Sercomm models so far.
Tested models
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] was tested against the following models from Sercomm:
  • Vodafone Power Station (SHG3000)
  • Vodafone Power Station WiFi 6 (SHG3060)
  • Vodafone WiFi 6 Station (RHG3006)
  • Vodafone Gigabox (SHG3000) - supplied by Vodafone Ireland
  • Vodafone H300S
To add the Vodafone Station hub to your Home Assistant instance, use this My button:
  • From the list, select Vodafone Station.
host
The IP address of the Vodafone Station router.
username
The username of the Vodafone Station router.
password
The password of the Vodafone Station router.
Options
Options for Vodafone Station can be set via the user interface, by taking the following steps:
  • If multiple instances of Vodafone Station are configured, choose the instance you want to configure.
  • Select the integration, then select Configure.
consider home
Number of seconds that must elapse before considering a disconnected device “not at home”.
Supported functionality
There is support for the following platform types within Home Assistant:
  • Device tracker - presence detection by looking at connected devices.
  • Sensor - external IP address, uptime, firmware, resources and network monitors.
  • Button - restart router, dsl/fiber/internet key connections.
Examples
Automation: reconnect / get new IP every night
automation:
- alias: "Reconnect Vodafone Station (Fiber)"
  triggers:
    - trigger: time
      at: "05:00:00"
  actions:
    - action: button.press
        entity_id: button.vodafone_station_xxxx_reconnect_fiber
YAML
Automation: notify connected device not home
automation:
- alias: "Apple TV disconnect"
  triggers:
    - platform: state
      entity_id: device_tracker.appletv
      to: "not_home"
  actions:
    -  action: notify.mobile_app_phone
         message: "TV lost network connection"
YAML
Automation: notify router CPU usage too high
automation:
- alias: "Vodafone Station CPU high cpu usage"
  triggers:
    - platform: numeric_state
      entity_id: sensor.vodafone_station_xxxx_cpu_usage
      above: 80
  actions:
         message: "Router CPU above 80%."
YAML
Data updates
This integration pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] data from the device every 30 seconds by default.
Additional info
Device tracker
Note: If you don’t want to automatically track newly detected devices, disable the integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] system option Enable new added entities.
Can’t set up the device
Symptom: “User already logged-in”
When trying to set up the integration, the form shows the message “User already logged-in”.
Description
This means that there is already a logged session to the Vodafone Station router.
Resolution
To resolve this issue, log out from all active sessions, or, if the session was abruptly closed, wait for the router timeout (usually 60 seconds).
  3. Next to the entry, select the three-dot menu. Then, select Delete.
