Utility Meter
The Utility Meter integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides functionality to track consumptions of various utilities (e.g., energy, gas, water, heating).
From a user perspective, utility meters operate in cycles (usually monthly) for billing purposes. This sensor will track a source sensor values, automatically resetting the meter based on the configured cycle. On reset an attribute will store the previous meter value, providing the means for comparison operations (e.g., “did I spend more or less this month?”) or billing estimation (e.g., through a sensor template that multiplies the metered value per the charged unit amount).
Some utility providers have different tariffs according to time or resource availability. The utility meter enables you to define the various tariffs supported by your utility provider and accounts for your consumption accordingly. When tariffs are defined a new entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] will show up, indicating the current tariff. To change the tariff, the user must perform an action, usually through an automation that can be based on time or other external sources (for example, a REST sensor).
Sensors created with this integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] are persistent, so values are retained across restarts of Home Assistant. The first cycle for each sensor will be incomplete; a sensor tracking daily usage will start to be accurate the next day after the integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] was activated. A sensor tracking monthly usage will present accurate data starting the first of the next month after being added to Home Assistant.
To add the Utility Meter helper to your Home Assistant instance, use this My button:
At the top of the screen, select the tab: Helpers.
Create helper button. -
From the list, select Utility Meter.
How often to reset the counter. If the offered reset cycles do not match your use case, consider using the YAML configuration below, which allows for creating CRON-style patterns.
Cycle reset occur at the beginning of the period. This option enables the offsetting of these beginnings, counted in days. If you need a more fine-grained offset, consider using the YAML configuration below, which allows for that.
Enable this if you would like to treat the source as a net meter. This will allow your counter to go both positive and negative.
Enable this if the source values are delta values since the last reading instead of absolute values. When this option is enabled, each new value received will be added as-is to the utility meter instead of adding the difference between the new value and previous value.
Enable this if the source sensor can reset, for example, a smart plug that resets on boot. The reset does not have to be to 0; when Net consumption is disabled, decreases in the source value are ignored. When Net consumption is enabled, negative differences are treated as valid consumption. When this option is disabled, the difference between the new value and the last valid value is added to the utility meter.
If activated, the sensor will always be available with the last totalized value, even if the source entity is unavailable or unknown. You need to understand that with this option activated, when the source entity becomes unavailable, the utility meter sensor will have the last totalized value and will not change until the source entity returns to a valid state.
If the meter reset cycle and reset offsets are too limited for your use case, consider using the YAML configuration below, which support CRON-style patterns that provide a greater flexibility.
YAML configuration
Alternatively, this integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] can be configured and set up manually via YAML
instead. To enable the Integration sensor in your installation, add the
following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
utility_meter:
energy:
source: sensor.energy_in_kwh
cycle: monthly
The entity ID of the sensor providing utility readings (energy, water, gas, heating).
An ID that uniquely identifies the utility_meter. Set this to a unique value to allow customization through the UI.
How often to reset the counter. Valid values are quarter-hourly, hourly, daily, weekly, monthly, bimonthly, quarterly and yearly. Cycle value bimonthly will reset the counter once in two months.
Cycle reset occur at the beginning of the period (0 minutes, 0h00 hours, Monday, day 1, January). This option enables the offsetting of these beginnings. Supported formats: offset: 'HH:MM:SS', offset: 'HH:MM' and Time period dictionary (see example below).
This option is mutually exclusive of cycle and offset. It provides an advanced method of defining when should the counter be reset. It follows common crontab syntax but extended to support more advanced scheduling. See the croniter library.
Set this to True if the source values are delta values since the last reading instead of absolute values. When this option is enabled, each new value received will be added as-is to the utility meter instead of adding the difference between the new value and previous value. For example, you should enable this when the source sensor returns readings like “1”, “0.5”, “0.75” versus “1”, “1.5”, “2.25”.
Set this to True if you would like to treat the source as a net meter. This will allow your counter to go both positive and negative.
Enable this if the source sensor can reset, for example, a smart plug that resets on boot. The reset does not have to be to 0; when net_consumption is disabled, decreases in the source value are ignored. When net_consumption is enabled, negative differences are treated as valid consumption. When this option is disabled, the difference between the new value and the last valid value is added to the utility meter.
When using the offset configuration parameter, the defined period must not be longer than 28 days.
Time period dictionary example
offset:
# At least one of these must be specified:
days: 1
hours: 0
minutes: 0
Some actions are only available if you have configured tariffs for the meter.
List of actions
The Utility Meter integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following actions. Each link below opens a dedicated page with examples, parameters, and a step-by-step UI walkthrough.
Calibrate a utility meter (
utility_meter.calibrate) Sets a utility meter sensor to a specific value. -
Reset a utility meter (
utility_meter.reset) Resets all counters of a utility meter back to zero.
Advanced configuration
The following configuration shows an example where 2 utility_meters (daily_energy and monthly_energy) track daily and monthly energy consumptions.
Both track the same sensor (sensor.energy) which continuously monitors the energy consumed.
4 different sensors will be created, 2 per utility meter and corresponding to each tariff.
Sensor sensor.daily_energy_peak, sensor.daily_energy_offpeak, sensor.monthly_energy_peak and sensor.monthly_energy_offpeak will automatically be created to track the consumption in each tariff for the given cycle.
The select.daily_energy and select.monthly_energy select entities will track the current tariff and allow changing the tariff.
utility_meter:
daily_energy:
cycle: daily
tariffs:
- peak
- offpeak
monthly_energy:
cycle: monthly
tariffs:
- peak
- offpeak
Assuming your energy provider tariffs are time based according to:
- peak: from 9h00 to 21h00
- offpeak: from 21h00 to 9h00 next day
a time based automation can be used:
automation:
triggers:
- trigger: time
at: "09:00:00"
variables:
tariff: "peak"
- trigger: time
at: "21:00:00"
variables:
tariff: "offpeak"
actions:
- action: select.select_option
entity_id: select.daily_energy
option: "{{ tariff }}"
entity_id: select.monthly_energy
Assuming your utility provider cycle is offset from the last day of the month
- cycles at 17h00 on the last day of the month
a cron(extended syntax used for last day of month) based utility meter can be used:
utility_meter:
monthly_energy:
cron: "0 17 L * *"
Advanced configuration for DSMR users
When using the DSMR integration to get data from the utility meter, each tariff (peak and off-peak) has a separate sensor. Additionally, there is a separate sensor for gas consumption. The meter switches automatically between tariffs, so an automation is not necessary in this case. But, you do have to set up a few more instances of the utility_meter integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more].
If you want to create a daily and monthly sensor for each tariff, you have to track separate sensors:
sensor.energy_consumption_tarif_1for tarif 1 power (for example off-peak) -
sensor.energy_consumption_tarif_2for tarif 2 power (for example peak) -
sensor.gas_consumptionfor gas consumption
So, tracking daily and monthly consumption for each sensor, will require setting up 6 entries under the utility_meter integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more].
utility_meter:
daily_energy_offpeak:
source: sensor.energy_consumption_tarif_1
name: Daily Energy (Offpeak)
cycle: daily
daily_energy_peak:
source: sensor.energy_consumption_tarif_2
name: Daily Energy (Peak)
cycle: daily
daily_gas:
source: sensor.gas_consumption
cycle: daily
monthly_energy_offpeak:
name: Monthly Energy (Offpeak)
cycle: monthly
monthly_energy_peak:
name: Monthly Energy (Peak)
cycle: monthly
monthly_gas:
cycle: monthly
Additionally, you can add template sensors to compute daily and monthly total usage. Important note, in these examples,
we use the is_number() function to verify the values
returned from the sensors are numeric. If this evaluates to false, None is returned.
template:
- sensor:
- name: 'Daily Energy Total'
device_class: energy
unit_of_measurement: kWh
state: >
{% if is_number(states('sensor.daily_energy_offpeak')) and is_number(states('sensor.daily_energy_peak')) %}
{{ states('sensor.daily_energy_offpeak') | float + states('sensor.daily_energy_peak') | float }}
{% else %}
None
{% endif %}
- name: 'Monthly Energy Total'
state: >
{% if is_number(states('sensor.monthly_energy_offpeak')) and is_number(states('sensor.monthly_energy_peak')) %}
{{ states('sensor.monthly_energy_offpeak') | float + states('sensor.monthly_energy_peak') | float }}
{% else %}
None
{% endif %}
Don’t add a sensor like Daily Energy Total above to the Energy dashboard. Because the two underlying utility meter sensors may not reset at the exact same moment, summing them can briefly record a false value in your long-term statistics that requires manual correction. Add each utility meter sensor to the dashboard separately instead. See the Energy dashboard FAQ for details.
