Twilio Call
The twilio_call
notification platform enables sending notifications via Voice, powered by Twilio
The requirement is that you have setup Twilio.
To use this notification platform in your installation, add the following to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
An E.164
Usage
Twilio is a notification platform and thus can be controlled by calling the notify action as described here. It will send a notification to all E.164 phone numbers in the notification target. See the notes above regarding the from_number
configuration variable for information about formatting phone numbers.
