Roth Touchline SL
The Roth Touchline SL climate integration enables you to control Roth Touchline SL underfloor heating systems.
You must have an account registered with the Roth Touchline SL dashboard.
To add the Roth Touchline SL integration to your Home Assistant instance, use this My button:
  • From the list, select Roth Touchline SL.
Entities
The integration will present each Roth Touchline SL zone as a climate entity, which can:
  • Display the current temperature
  • Display the current humidity
  • Set a target temperature
  • Assign to a configured “Global Schedule” using Home Assistant climate entity presets.
