Tesla Fleet
The Tesla Fleet integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control Tesla vehicles and energy sites using the Tesla Fleet API.
You need to configure developer credentials and host a public key file to allow Home Assistant to communicate with your Tesla account.
- A Tesla account with verified email
- A web domain to host your public key file:
- NGINX Home Assistant SSL proxy app (recommended)
- External hosting service, such as FleetKey.net or MyTeslamate.com
The China region is currently not supported by this integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more].
Tesla Developer Application
Create a Tesla Developer Application to connect Home Assistant with the Tesla Fleet API.
Create a developer application:
- Go to developer.tesla.com/request
- Select your Tesla account from the dropdown
Enter application details:
- Application name: A name to identify the application
- Description: Enter a brief description of your integration
- Purpose of Usage: Explain how you’ll use the API (e.g., “Home Assistant”)
Configure client details:
- OAuth Grant Type: Select Authorization Code and Machine-to-Machine
- Allowed Origin URL(s): Enter your domain’s URL, for example
https://yourdomain.com/ - Allowed Redirect URI: Enter one of the following:
- The literal string
https://my.home-assistant.io/redirect/oauthif theMy Home Assistantintegration is enabled (it is by default).- Home Assistant uses this service by default to redirect requests towards your instance.
<HOME_ASSISTANT_URL>/auth/external/callbackif you do not have theMy Home Assistantintegration enabled.
- Allowed Returned URL(s): Leave this field empty (not required)
Select desired API scopes:
- Vehicle Information (mandatory for vehicles)
- Vehicle Location (recommended)
- Vehicle Commands (recommended)
- Energy Product Information (mandatory for energy products)
- Energy Product Settings (recommended)
Set up billing (optional):
- Tesla provides $10 monthly credit for personal use
- You can add billing details later if needed
Save your credentials:
- After creating the application, go to View Details > Credentials & APIs
- Note your Client ID and Client Secret - you’ll need these to configure Home Assistant.
To add the Tesla Fleet hub to your Home Assistant instance, use this My button:
From the list, select Tesla Fleet.
Add application credentials
- Enter your application Client ID and Client Secret from your Tesla Developer Application.
- This step will be skipped if you already have exactly one Tesla Fleet application credential already configured.
Authenticate with Tesla:
- You’ll be redirected to Tesla’s login page.
- Enter your Tesla account credentials.
- On the authorization page, select Select All and then Allow to allow all the scopes you previously selected.
Redirect to Home Assistant:
- Confirm you want to Link account to Home Assistant.
Select region:
- Home Assistant detects the region for your Tesla account and selects it for you, so most people can just select Submit.
- If your vehicles or energy sites are registered in a different region, select the correct region from the list before continuing.
Enter domain:
- Enter the domain name you intend to host your public key on.
- This domain should be the same or a subdomain of your origin domain, and must use a valid SSL certificate.
Register public key:
- Upload the public key shown to the domain you entered in step 5 at
.well-known/appspecific/com.tesla.3p.public-key.pem.
Install virtual key:
- Use your smartphone to scan the QR code or enter the address to install your public key on your vehicles with the Tesla app.
- This process needs to be repeated for each vehicle, excluding Model S and Model X vehicles manufactured before 2021.
Hosting with NGINX app (optional)
Create the NGINX configuration:
echo 'location /.well-known/appspecific/com.tesla.3p.public-key.pem { root /share/tesla; }' > /share/nginx_proxy_default_tesla.conf -
Copy the public key shown during setup to
/share/tesla -
Configure the NGINX app:
- Go to Settings > Apps > NGINX Home Assistant SSL proxy > Configuration
- Change
customize.activefromfalsetotrue - Leave
config.defaultat its default value:nginx_proxy_default*.conf
Restart the NGINX app and verify your public key is accessible at:
https://yourdomain.com/.well-known/appspecific/com.tesla.3p.public-key.pem
Data updates
The integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] each vehicle every 10 minutes while it’s awake. This is designed to stay within Tesla’s $10 monthly credit for most users, which you can monitor usage in the Tesla Developer Dashboard. Energy product APIs are free to use.
If you need different polling intervals, you can define a custom polling interval.
Command signing
Certain vehicles, including all vehicles manufactured since late 2023, require vehicle commands to be signed with a private key. All actionsActions are used in several places in Home Assistant. As part of a script or automation, actions define what is going to happen once a trigger is activated. In scripts, an action is called sequence. [Learn more] on vehicle entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] will fail with an error if this is required and the key has not been set up correctly.
Your public key must be added to each of these vehicles by visiting https://tesla.com/_ak/YOUR_DOMAIN and following the instructions in the Tesla app.
If you’re using an iPhone, you may need to use Safari to open the webpage and finish the setup.
For more details see Tesla Fleet API vehicle commands documentation.
Generating your own key pair
The integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] generates a private key automatically at config/tesla_fleet.key. You can replace it with your own key (such as one from another Home Assistant instance) before configuring the integration. You can generate your own key pair following Tesla’s documentation.
Entities
These are the entities available in the Tesla Fleet integration. Not all entities are enabled by default, and not all values are always available.
Vehicles
| Domain | Name | Enabled |
| Binary sensor | Battery heater | No |
| Binary sensor | Cabin overheat protection actively cooling | No |
| Binary sensor | Charge cable | Yes |
| Binary sensor | Charger has multiple phases | No |
| Binary sensor | Dashcam | No |
| Binary sensor | Front driver door | Yes |
| Binary sensor | Front driver window | Yes |
| Binary sensor | Front passenger door | Yes |
| Binary sensor | Front passenger window | Yes |
| Binary sensor | Preconditioning enabled | No |
| Binary sensor | Preconditioning | No |
| Binary sensor | Rear driver door | Yes |
| Binary sensor | Rear driver window | Yes |
| Binary sensor | Rear passenger door | Yes |
| Binary sensor | Rear passenger window | Yes |
| Binary sensor | Scheduled charging pending | No |
| Binary sensor | Status | Yes |
| Binary sensor | Tire pressure warning front left | No |
| Binary sensor | Tire pressure warning front right | No |
| Binary sensor | Tire pressure warning rear left | No |
| Binary sensor | Tire pressure warning rear right | No |
| Binary sensor | Trip charging | No |
| Binary sensor | User present | Yes |
| Button | Flash lights | Yes |
| Button | HomeLink | Yes |
| Button | Honk horn | Yes |
| Button | Keyless driving | Yes |
| Button | Play fart | Yes |
| Button | Wake | Yes |
| Climate | Cabin overheat protection | No |
| Climate | Climate | Yes |
| Cover | Charge port door | Yes |
| Cover | Frunk | Yes |
| Cover | Sunroof | No |
| Cover | Trunk | Yes |
| Cover | Vent windows | Yes |
| Device tracker | Location | Yes |
| Device tracker | Route | Yes |
| Lock | Charge cable lock | Yes |
| Lock | Lock | Yes |
| Media player | Media player | Yes |
| Number | Charge current | Yes |
| Number | Charge limit | Yes |
| Select | Seat heater front left | Yes |
| Select | Seat heater front right | Yes |
| Select | Seat heater rear center | No |
| Select | Seat heater rear left | No |
| Select | Seat heater rear right | No |
| Select | Seat heater third row left | No |
| Select | Seat heater third row right | No |
| Select | Steering wheel heater | Yes |
| Sensor | Battery level | Yes |
| Sensor | Battery range | Yes |
| Sensor | Charge cable | No |
| Sensor | Charge energy added | Yes |
| Sensor | Charge rate | Yes |
| Sensor | Charger current | Yes |
| Sensor | Charger power | Yes |
| Sensor | Charger voltage | Yes |
| Sensor | Charging | Yes |
| Sensor | Destination | No |
| Sensor | Distance to arrival | Yes |
| Sensor | Driver temperature setting | No |
| Sensor | Estimate battery range | No |
| Sensor | Fast charger type | No |
| Sensor | Ideal battery range | No |
| Sensor | Inside temperature | Yes |
| Sensor | Odometer | No |
| Sensor | Outside temperature | Yes |
| Sensor | Passenger temperature setting | No |
| Sensor | Power | No |
| Sensor | Shift state | No |
| Sensor | Speed | No |
| Sensor | State of charge at arrival | No |
| Sensor | Time to arrival | Yes |
| Sensor | Time to full charge | Yes |
| Sensor | Tire pressure front left | No |
| Sensor | Tire pressure front right | No |
| Sensor | Tire pressure rear left | No |
| Sensor | Tire pressure rear right | No |
| Sensor | Traffic delay | No |
| Sensor | Usable battery level | No |
| Switch | Auto seat climate left | Yes |
| Switch | Auto seat climate right | Yes |
| Switch | Auto steering wheel heater | Yes |
| Switch | Charge | Yes |
| Switch | Defrost | Yes |
| Switch | Sentry mode | Yes |
| Update | Update | Yes |
Energy sites
| Binary sensor | Backup capable | Yes |
| Binary sensor | Grid services active | Yes |
| Binary sensor | Grid services enabled | Yes |
| Binary sensor | Storm watch active | Yes |
| Number | Backup reserve | Yes |
| Number | Off grid reserve | Yes |
| Select | Allow export | Yes |
| Select | Operation mode | Yes |
| Sensor | Battery power | Yes |
| Sensor | Consumer imported from battery | No |
| Sensor | Consumer imported from generator | No |
| Sensor | Consumer imported from grid | No |
| Sensor | Consumer imported from solar | No |
| Sensor | Energy left | Yes |
| Sensor | Generator exported | Yes |
| Sensor | Generator power | No |
| Sensor | Grid exported | Yes |
| Sensor | Grid exported from battery | No |
| Sensor | Grid exported from generator | No |
| Sensor | Grid exported from solar | No |
| Sensor | Grid imported | No |
| Sensor | Grid power | Yes |
| Sensor | Grid services exported | No |
| Sensor | Grid services imported | No |
| Sensor | Grid services power | Yes |
| Sensor | Home usage | Yes |
| Sensor | Island status | Yes |
| Sensor | Load power | Yes |
| Sensor | Percentage charged | Yes |
| Sensor | Solar exported | No |
| Sensor | Solar generated | Yes |
| Sensor | Solar power | Yes |
| Sensor | Total pack energy | No |
| Sensor | Version | Yes |
| Sensor | VPP backup reserve | Yes |
| Switch | Allow charging from grid | Yes |
| Switch | Storm watch | Yes |
Wall connector
| Sensor | Fault state | No |
| Sensor | Power | Yes |
| Sensor | State | Yes |
| Sensor | Vehicle | Yes |
Vehicle sleep
Constant API pollingData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] will prevent most Model S and Model X vehicles manufactured before 2021 from sleeping. The integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] automatically stops pollingData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] these vehicles for 15 minutes after inactivity. You can call the homeassistant.update_entity actionActions are used in several places in Home Assistant. As part of a script or automation, actions define what is going to happen once a trigger is activated. In scripts, an action is called sequence. [Learn more] to force pollingData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more], which will reset the timer.
Tesla Developer Dashboard does not continue after selecting Next
Symptom
When configuring Client Details in the Tesla Developer Dashboard, selecting Next does not continue to the next step and no validation error is shown.
Resolution
Tesla may reject some origin domains without displaying a validation error. ddns.net hostnames have been observed to be rejected. If your origin URL uses ddns.net, use a different hostname that does not end in ddns.net, or use an external hosting service such as FleetKey.
- Setup errors: Verify your public key is accessible at the correct URL and you’ve completed all registration steps with Tesla
Command failures: Ensure
tesla_fleet.keyexists in your Home Assistant config directory and add your public key to vehicles viahttps://tesla.com/_ak/YOUR_DOMAIN - IntegrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] stopped working: Use the reconfigure option in Settings > Devices & services > Tesla Fleet
- Access to this resource is not authorized: Check your Tesla Developer Dashboard to ensure you haven’t exceeded your usage limits and add billing information if required. In certain countries, the Fart (remote boombox) command will also throw this error where its usage is illegal.
If you have an error with your credentials, you can delete them in the Application Credentials user interface.
menu. Then, select Delete.
- Removing the integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] does not delete your Tesla Developer Application - you can remove it manually from the Tesla Developer Dashboard if no longer needed.
