Synology SRM
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to detect presence by looking at connected devices to a Synology SRM
To use this device tracker in your installation, add the following to your configuration.yaml
The Synology SRM router host or IP address, e.g., 192.168.1.1
or router.mydomain.local
For instructions on creating multiple administrators on SRM, please refer to the Synology Knowledge Center
List of models known to be supported:
- RT1900ac
- RT2600ac
- MR2200ac
- RT6600ax
See the device tracker integration page for instructions on how to configure the people to be tracked.
