Switcher
This Switcher
integration allows you to control your Switcher Devices
Supported devices:
- Switcher Power Plug
- Switcher Touch (from firmware 1.51)
- Switcher V2 (Espressif chipset - from firmware 3.21)
- Switcher V2 (Qualcomm chipset - from firmware 72.32)
- Switcher V4
- Switcher Mini
- Switcher Breeze
- Switcher Runner
- Switcher Runner S11
- Switcher Runner S12
- Switcher Light SL01
- Switcher Light SL01 Mini
- Switcher Light SL02
- Switcher Light SL02 Mini
- Switcher Light SL03
Devices that require a token:
If you completed the integration setup but are still unable to control the device, please make sure your device’s firmware is up-to-date.
To enhance security, certain Switcher devices require a token for operation. In order to integrate your token-based Switcher devices with Home Assistant, you’ll need the following information:
The username of your Switcher Account: To find the username, open the Switcher app.
Local control key token: To find the local control key token, browse to the Switcher GetKey API
, enter your Switcher account username (which is an email address), and press Send Me The Code. The token will be sent to you by email. It will look something like this:
zvVvd7JxtN7CgvkD1Psujw==
To add the Switcher integration to your Home Assistant instance, use this My button:
From the list, select Switcher.
Buttons
For Switcher Breeze the integration provides the following buttons:
For devices that are also controlled in other ways or often go out of sync with Switcher Breeze, there are
Assume on
&Assume off
buttons which you can use to can tell Switcher Breeze if your device is currently running or not without sending a new command to the device. -
For devices which do not support swing status for the vertical swing, the integration provides separate
Vertical swing on
&Vertical swing off
buttons.
Covers
For Switcher cover control devices (Switcher Runner, Switcher Runner S11, Switcher Runner S12) the integration allows you to control its covers open/close state, set specific covers position and get information about the cover direction (UP/DOWN/STOP).
Lights
For Switcher light control devices (Switcher Runner S11, Switcher Runner S12, and Switcher Lights), the integration allows you to control its lights on/off state.
Sensors
For Switcher power control devices (Switcher Power Plug, Switcher Touch, Switcher V2/V4) the integration provides the following sensors:
Sensor Name | Description | Example |
Auto Shutdown * |
The auto shutdown time limit configured on the device | 01:30:00 |
Remaining Time * |
Time remaining to shutdown (auto or timer) | 01:29:41 |
Electric Current |
The electric current in amps | 12.5 A |
Power Consumption |
The power consumption in watts | 2756 W |
*Currently not supported for Switcher Power Plug
For Switcher Breeze the integration provides the following sensor:
Current temperature |
The current temperature in celsius | 25.0 °C |
Switches
For Switcher cover control devices (Switcher Runner, Switcher Runner S11, Switcher Runner S12), the integration allows you to control its child lock state; ON means locked, and OFF means unlocked.
Actions
For Switcher power control devices (Switcher Touch, Switcher V2/V4) the integration provides the following sensors:
Action: switcher_kis.set_auto_off
You can use the switcher_kis.set_auto_off
action to set the auto-off configuration setting for the device.
Meaning the device will turn itself off when reaching the auto-off configuration limit.
Data attribute | Mandatory | Description | Example |
entity_id |
Yes | Name of the entity id associated with the integration, used for permission validation | switch.switcher_kis_boiler |
auto_off |
Yes | Time period string containing hours and minutes | “02:30” |
Action: switcher_kis.turn_on_with_timer
You can use the switcher_kis.turn_on_with_timer
action to turn on the switcher device with timer.
Meaning the device will turn itself off when timer ends. Note: This does not affect the auto off timer.
entity_id |
timer_minutes |
Yes | Integer containing timer minutes (valid range 1 to 150) | 90 |
Notes
Make sure that Home Assistant host’s firewall allows incoming traffic on UDP ports 10002, 10003, 20002 & 20003 and outgoing connections to Switcher device(s) on TCP ports 9957 & 10000. If Home Assistant and the Switcher device(s) are not on the same network, you will also need to have their traffic properly forwarded between the two networks.
