SwitchBot Cloud
The SwitchBot Cloud integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to control SwitchBot devices connected through the SwitchBot hub.
To use this integration, you will need at least a SwitchBot Hub and a SwitchBot account to get a token and secret key from the SwitchBot mobile app in Profiles > Preferences > About > Developer Options. If you don’t see developer options, tap the version number 10 times. See also SwitchBot’s blog for more information specific to the app.
Device names configured in the SwitchBot app are transferred into Home Assistant.
To add the SwitchBot Cloud hub to your Home Assistant instance, use this My button:
From the list, select SwitchBot Cloud.
Supported devices
Plugs and switches
- Bot (WoHand)
- Relay Switch 2PM
- Relay Switch 1
- Relay Switch 1PM
- Plug Mini (WoPlug)
- Plug Mini (HomeKit Enabled)
- Plug Mini (EU)
- Plug (Wi-Fi only, only available in Japan)
Cover
- Curtain (WoCurtain) (version 1 & 2)
- Curtain 3 (WoCtn3)
- Curtain 4
- Blind Tilt (WoBlindTilt)
- Roller Shade
- Garage Door Opener
Lights
- LED Strip Light 3
- Floor Lamp
- Color Bulb (WoBulb)
- Light Strip (WoStrip)
- RGBICWW Floor Lamp
- RGBICWW Strip Light
- Ceiling Light / Ceiling Light Pro (Japan only)
- RGBIC Neon Rope Light
- RGBIC Neon Wire Rope Light
- Candle Warmer Lamp
- Permanent Outdoor Lights
Locks
- Lock (WoLock)
- Lock Pro (WoLockPro)
- Lock Pro Wifi
- Lock Lite
- Lock Ultra
- Lock Ultra Max
- Lock Vision
- Lock Vision Pro
Sensors
- Meter
- Meter Plus
- Indoor/Outdoor Meter (WoIOSensorTH)
- Meter Pro
- Meter Pro CO2 Monitor
- Contact Sensor
- Motion Sensor
- Water Leak Detector
- Climate Panel
- Presence Sensor
- Weather Station
Hubs
- Hub 2 (WoHub2) (currently only supports retrieving sensor data, does not yet support device control)
- Hub 3 (currently only supports retrieving sensor data, does not yet support device control)
- IR appliances exposed through the different hubs:
- ON/OFF for all appliance types except for Others
- Change temperature and mode for Air Conditioner
Humidifiers
Vacuums
Fans
- Circulator Fan
- Battery Circulator Fan
- Battery Circulator Fan 2 Pro
- Standing Fan
- Air Purifier
- Air Purifier Table
Water heater
Supported functionality
Plugs and switches
Bot
Features:
- acted as a Switch in
switchModeandcustomizeMode, as a Button inpressMode - turn on or off
- press
- get battery level
Plug Mini
Features:
- turn on or off
- get power consumption readings
Relay Switch 2PM
Features: displayed as two switches with the following properties or actions individually,
- turn on or off
- get power
- get voltage
- get current
- get daily used electricity or power consumption
Relay Switch 1
Features:
- turn on or off
Relay Switch 1PM
Features:
- turn on or off
- get power
- get voltage
- get current
Plug
Features:
- turn on or off
Cover
Curtain
Features:
- open/close/pause
- set position
- get position
- get battery level
- get calibration state
Curtain 3
Features:
- open/close/pause
- set position
- get position
- get battery level
Curtain 4
Features:
- open/close/pause
- set position
- get position
- get battery level
Blind Tilt
Features:
- close up/close down
- set position
- get position
- get battery level
Roller Shade
Features:
- open/close
- set position
- get position
- get battery level
Garage Door Opener
Features:
- open/close
- set position
- get position
Sensors
Meter
Features:
- get temperature
- get humidity
- get battery level
Meter Plus
Features:
- get temperature
- get humidity
- get battery level
Features:
- get temperature
- get humidity
- get battery level
Meter Pro
Features:
- get temperature
- get humidity
- get battery level
Features:
- get temperature
- get humidity
- get carbon dioxide
- get battery level
Contact Sensor
Features:
- get motion detection state
- get light state
- get open state
- get battery level
Motion Sensor
Features:
- get battery level
Presence Sensor
Features:
- get light level
- get battery level
Water Leak Detector
Features:
- get leak state
- get battery level
Climate Panel
Features:
- get temperature
- get humidity
- get battery level
- light detect
- motion detect
Weather Station
Features:
- get temperature
- get humidity
- get battery level
Lights
LED Strip Light 3
Features:
- turn on or off
- change brightness
- change color temperature
- change color
Floor Lamp
Features:
- turn on or off
- change brightness
- change color
Color Bulb
Features:
- turn on or off
- change brightness
- change color
LED Strip Light
Features:
- turn on or off
- change brightness
- change color
Features:
- turn on or off
- change brightness
RGBICWW Floor Lamp / RGBICWW Strip Light
Features:
- turn on or off
- change brightness
- change color
RGBIC Neon Rope Light / RGBIC Neon Wire Rope Light
Features:
- turn on or off
- change brightness
- change color
Candle Warmer Lamp
Features:
- turn on or off
- change brightness
Features:
- turn on or off
- change brightness
- change color
Locks
Lock
Features:
- Lock or unlock
- open or closed state
- calibration state
- get battery level
Lock Pro
Features:
- Lock or unlock
- calibration state
- get battery level
Hubs
Some of the hubs can be served as a bridge while the sensor data can be retrieved. Hub 2 displays temperature and humidity through a sensor cable. Without a digital display, Hub Mini Matter Enabled can also read from a sensor cable.
Hub 2
Features:
- get temperature
- get humidity
Hub 3
Features:
- get temperature
- get humidity
- get light level
Humidifiers
Humidifier entities are added for Humidifier and Evaporative Humidifier.
Humidifier
Features:
- turn on
- turn off
- set mode
- set humidity
Note: Not all modes support unless you bind the temperature and humidity sensor.
Features:
- turn on
- turn off
- set mode
- set humidity
Fans
Battery Circulator Fan / Circulator Fan / Standing Fan / Battery Circulator Fan 2 Pro
Features:
- turn on
- turn off
- set speed, only applicable for [direct mode]
- set mode
- get battery, only applicable for [Battery Circulator Fan / Standing Fan / Battery Circulator Fan 2 Pro]
- set night light, only applicable for [Battery Circulator Fan / Standing Fan / Battery Circulator Fan 2 Pro]
Air Purifier
Features:
- get states
- turn on
- turn off
- set mode
Air Purifier Table
Features:
- get states
- turn on
- turn off
- set mode
Vacuums
Vacuum entities are added for K10+, K10+ Pro, K10+ Pro Combo, K11+, K20+ Pro, S10, S20.
Features:
- get states
- start/clean
- pause
- set cleaning mode
- return to base
- get battery
Water Heater
Smart Radiator Thermostat
Features:
- turn on
- turn off
- set temperature
- get temperature
- set mode
- get battery
AI Art Frame
Features:
- get battery
- switch picture
- display current picture
- upload a new picture from a web address, using the Upload AI Art Frame image action
List of actions
The SwitchBot Cloud integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following actions. Each link below opens a dedicated page with examples, parameters, and a step-by-step UI walkthrough.
Upload AI Art Frame image (
switchbot_cloud.upload_art_frame_image) Uploads an image from a web address to one or more SwitchBot AI Art Frame devices.
Important considerations
Each sensor will request a status update from the SwitchBot Cloud API once every 10 minutes (600 seconds). The SwitchBot Cloud API limits users to 10,000 requests per day.
For IR Appliances, the state is inferred from previous commands in Home Assistant and might not reflect reality if you use other ways to control the device.
Webhook support
SwitchBot’s cloud pushes state updates to Home Assistant through a webhook. This is how vacuums, along with the water leak, contact, motion, and presence sensors, receive their state updates. For SwitchBot’s cloud to deliver this webhook, your Home Assistant instance must be reachable from the internet, which requires one of the following:
- A publicly reachable
external_url, or - A Home Assistant Cloud subscription, in which case the webhook is delivered automatically through a cloudhook.
On a local-only installation with neither of these, SwitchBot’s cloud cannot deliver the webhook, and these devices do not receive updates.
Only ONE webhook URL seems to be accepted by the SwitchBot’s cloud. So, if you want several applications notified, you need to use a “proxy” to re-dispatch the message to the other applications.
