Suez Water
The Suez Water integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] fetches your water consumption data from the French water provider Tout Sur Mon Eau website.
Sensors
- The Water usage yesterday sensor shows yesterday’s water consumption data if that data is available.
- The Water price sensor shows the current water price in euros per cubic meter (€/m3).
Extra attributes
Extra attributes of Water usage yesterday sensor:
- Daily consumption for the current month
- Daily consumption for the previous month
- Monthly consumption for the last 26 months
- Highest monthly consumption
- Last year total consumption
- Current year total consumption
Energy
The integration provides statistics containing all available data from Suez. The data is fetched every 12 hours and is updated once a day by Suez.
You can find the statistics in Settings > Tools > Statistics and search for “suez_water”. Note: Due to Suez’s daily update schedule, data for the current day will not be available, and yesterday’s data may be delayed depending on when you check
At the initial setup, the integration pulls historical daily usage since the counter installation.
- The Energy dashboard must be enabled in your Home Assistant instance. If you haven’t set it up yet, please refer to the Energy dashboard documentation.
In the configuration of the energy dashboard (Settings > Dashboards > Energy):
- Select Add consumption for Water source.
- Select Suez water Consumption followed by your counter ID (for example,
Suez water Consumption 1234567890) for the consumed water. - Select Suez water Cost followed by your counter ID for the total price
Statistics details
Suez water consumption (
suez_water_water_consumption_statistics_{counter_id}):- Contains daily water consumption in liters
- Provides both state and sum statistics for each day
Suez water cost (
suez_water_water_cost_statistics_{counter_id}):- Contains daily cost calculations in euros
- Important: Historical costs are calculated using the current water price since historical price information is not available. If water prices have changed over time, the calculated historical costs may not match your actual bills.
To add the Suez Water service to your Home Assistant instance, use this My button:
From the list, select Suez Water.
The water counter ID. It should be found automatically during setup. If it was not found, follow these steps to find your counter ID:
- Go to your Tout Sur Mon Eau user account page. You must be authenticated to access this page.
- Open the browser’s developer tools (press F12 or right-click > Inspect).
- In the developer tools, go to the Network tab.
- Reload the page.
- In the Network tab, search for
id_PDS=. The 10-digit number that follows it is your counter ID.
Data updates
The integration pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] your Suez account every 12 hours.
This integration can be removed by following these steps:
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
