Smart Rollos
Support for devices by Smart Rollos in Home Assistant is provided by the Motionblinds integration.
Smart Rollos devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the Motionblinds integration.
To add the Smart Rollos integration to your Home Assistant instance, use this My button:
Smart Rollos can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Smart Rollos.
Usage information
For more documentation on how to use Smart Rollos in Home Assistant, please refer to the Motionblinds integration documentation page.
