Shopping list
The Shopping list integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to keep track of shopping list items.
Your shopping list will be accessible from the sidebar, and you can optionally add the To-do list card to your dashboard. With the conversation integration, you can add items to your shopping list using voice commands like “Add eggs to my shopping list.”
To add the Shopping list integration to your Home Assistant instance, use this My button:
From the list, select Shopping list.
Actions
You can add or remove items from your shopping list by using the following actions.
Action shopping_list.add_item
Add an item to the shopping list.
name |
no | Name of the item to add. Example: “Milk” |
Action shopping_list.remove_item
Remove the first item with matching name from the shopping list.
name |
no | Name of the item to remove. Example: “Milk” |
Action shopping_list.complete_item
Mark the first item with matching name as completed in the shopping list. It does not remove the item.
name |
no | Name of the item to mark as completed. Example: “Milk” |
Action shopping_list.incomplete_item
Mark the first item with matching name as incomplete in the shopping list.
name |
no | Name of the item to mark as incomplete. Example: “Milk” |
Action shopping_list.complete_all
Mark all items as completed in the shopping list (without removing them from the list).
Action shopping_list.incomplete_all
Mark all items as incomplete in the shopping list.
Action shopping_list.clear_completed_items
Clear completed items from the shopping list.
Action shopping_list.sort
Sort all items by name in the shopping list.
reverse |
yes | Whether to sort in reverse (descending) order. (default: False ) |
Using in automations
A shopping_list_updated
event is triggered when items in the list are modified, with the following data payload attached to it. This can be used to trigger automations such as sending a push notification when someone adds an item to the shopping list, which when clicked, will open the list.
Data payload attribute | Description |
action |
What action was taken on the item. Either add for a new item being added, update for an item being updated, or remove for an item being removed. |
item |
A dictionary containing details of the item that was updated. |
item.id |
A unique ID for this item |
item.name |
The text attached to the item, for example Milk
item.complete |
A boolean indicated whether the item has been marked as complete. |
You can also trigger an automation when a shopping_list_updated
event was triggered by any of the following actions:
clear
: A completed item was cleared from the list. -
sorted
: The items in the list were sorted by name. -
reorder
: An item has been reordered in the list. -
update_list
: All items have been updated.
In these cases, the event does not return a list item.
