SensorPush Cloud
Integrates SensorPush Cloud
A G1 WiFi Gateway
Sensor entities (temperature, humidity, barometric pressure) will not be available to Home Assistant until you have activated the device with the SensorPush app on iOS or Android.
Supported devices
- HT1 Temperature and Humidity Smart Sensor
- HT.w Water-Resistant Temperature / Humidity Smart Sensor
- HTP.xw Extreme Accuracy Water-Resistant Temperature / Humidity / Barometric Pressure Smart Sensor
To add the SensorPush Cloud integration to your Home Assistant instance, use this My button:
From the list, select SensorPush Cloud.
Sensors
For each device, the following sensors are created:
Sensor | Description |
altitude |
Measures the altitude. (disabled by default) |
atmospheric_pressure |
Measures the barometric pressure. (disabled by default) |
battery_voltage |
Measures the battery voltage. (disabled by default) |
dewpoint |
Measures the dew point. (disabled by default) |
humidity |
Measures the relative humidity. |
signal_strength |
Measures the Bluetooth signal strength. (disabled by default) |
temperature |
Measures the temperature. |
vapor_pressure |
Measures the vapor-pressure deficit. (disabled by default) |
Known limitations
is not available on HT1 and HT.w series devices.
- Next to the entry, select the three-dot
menu. Then, select Delete.
