Satel Integra
The Satel Integra integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to connect your Satel Integra alarm system to Home Assistant to control and monitor your alarm system.
- Binary sensor: Reports on zone or output statuses
- Switch: allows for setting states of selected outputs
- Alarm control panel: represents the zones (in Polish: “strefa”). Reports its status, and can be used to arm/disarm the partition
- Sensor: Reports zone temperatures for zones that have temperature support
The module communicates via Satel’s open TCP protocol published on their website. It subscribes for new events coming from alarm system and reacts to them immediately.
Supported devices
The integration only supports the ETHM-1 Plus, with firmware version 2.00 or greater. Only the Integra line of alarm systems is supported.
- Open the DLOADX installer program.
- Open your existing project file.
- Open the System and hardware structure tab.
- Navigate to the Hardware section, expand the tree and select the ETHM-1 Plus module.
- Select the Integration checkbox.
- Configure encryption:
- If you want to use an unencrypted connection, clear the Encrypted integration checkbox.
- If you want to use an encrypted connection, select the Encrypted integration checkbox and note the integration encryption key you configured in the Keypads module from the navigation tree.
If you do not have access to the DLOADX program or your project file, ask your installer to adjust the settings for you.
To add the Satel Integra device to your Home Assistant instance, use this My button:
From the list, select Satel Integra.
Encryption key to use if an encrypted connection is used, as configured in DLOADX for the ETHM-1 Plus module. Leave empty if not using an encrypted connection.
Configuring partitions, zones, and outputs
After setting up the connection details, you can configure partitions, zones, and outputs as Subentries on the Satel Integra integration page.
A list of all partition, zone, and output IDs can be acquired by running the DLOADX program and connecting to your alarm. To create the respective entities, select the Add partition, Add zone, Add output, or Add switchable output buttons. Follow the instructions in the UI to set up the individual entities. Result: Each partition will have its own alarm panel. Each zone and output will have a binary sensor, and a switch will be created for each switchable output. Sensors will be created for each zone that has temperature sensor support enabled.
Having configured the zones and the outputs, you can use them for automation, such as to react on the movement in your bedroom. For example:
alias: "Flick the input switch when movement in bedroom detected"
triggers:
- trigger: state
entity_id: "binary_sensor.bedroom"
to: "on"
actions:
- action: input_boolean.turn_on
entity_id: input_boolean.movement_detected
This integration follows standard integration removal. Once the integration is removed, consider disabling the communication ability to the ETHM-1 Plus module using DLOADX to reduce security risks.
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
