RESTful Command
This integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] can expose regular REST commands as actions. Actions can be called from a script or in automation.
To use this integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more], add the following lines to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file.
After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes.
rest_command:
example_request:
url: "http://example.com/"
The name used to expose the action. E.g., in the above example, it would be ‘rest_command.example_request’.
The URL (supports template) for sending request.
A string/template to send with request.
Type of HTTP authentication. Either basic or digest.
Allow insecure ciphers for the request. This is useful for older servers/devices that do not support modern ciphers.
Examples
Basic example which uses PUT method and payload encoded as form data
This example implements 2 REST commands to add actions for the missing shuffle functionality of the iTunes integration.
rest_command:
shuffle_on:
url: "http://YOUR_ITUNES-API_SERVER_IP:8181/shuffle"
method: put
content_type: "application/x-www-form-urlencoded"
payload: "mode=songs"
shuffle_off:
method: put
payload: "mode=off"
Using digest authentication
This example shows how to use digest authentication with a REST command:
rest_command:
secured_command:
url: "http://example.com/api/secure-endpoint"
method: post
authentication: digest
username: "your_username"
password: "your_password"
payload: '{"data": "example"}'
content_type: "application/json"
Using REST command Response in automations
REST commands provide an action response in a dictionary containing status (containing the HTTP response code), content containing the response body as text or JSON and headers containing the response headers.
This response can be accessed in automations using response_variable.
The following example shows how the REST command response may be used in automations. In this case, checking the Traefik API for errors.
# Create a ToDo notification based on file contents
automation:
- alias: "Check API response"
triggers:
actions:
- action: rest_command.traefik_get_rawdata
response_variable: traefik_response
- if: "{{ traefik_response['status'] == 200 }}"
then:
- alias: "Parse data"
variables:
routers: "{{ traefik_response['content']['routers'] }}"
router_errors: >
{%- for router in routers -%}
{%- if 'error' in routers[router] -%}
{{router}}: {{ routers[router]['error'] }}
{% endif -%}
{%- endfor -%}
got_errors: "{{ router_errors|length > 0 }}"
- if: "{{ got_errors }}"
then:
- action: notify.mobile_app_iphone
title: "Traefik errors"
message: "{{ router_errors }}"
else:
title: "Could not reach Traefik"
message: "HTTP code: {{ traefik_response['returncode'] }}"
rest_command:
traefik_get_rawdata:
url: http://127.0.0.1:8080/api/rawdata
method: GET
Using templates to change the payload based on entities
The commands can be dynamic, using templates to insert values of other entities. Actions support variables for doing things with templates.
This example uses templates for dynamic parameters.
rest_command:
my_request:
url: https://slack.com/api/users.profile.set
method: POST
headers:
authorization: !secret rest_headers_secret
accept: "application/json, text/html"
user-agent: 'Mozilla/5.0 {{ useragent }}'
payload: '{"profile":{"status_text": "{{ status }}","status_emoji": "{{ emoji }}"}}'
content_type: 'application/json; charset=utf-8'
verify_ssl: true
How to test your new REST command
Call the new action from developer tools in the sidebar with some data like:
"status":"My Status Goes Here",
"emoji":":plex:"
Using a REST command as an action in an automation
automation:
- alias: "Arrive at Work"
triggers:
- trigger: zone
entity_id: device_tracker.my_device
zone: zone.work
event: enter
actions:
- action: rest_command.my_request
status: "At Work"
emoji: ":calendar:"
