RAPT Bluetooth
Integrates RAPT Pill hydrometers into Home Assistant.
To add the RAPT Bluetooth device to your Home Assistant instance, use this My button:
From the list, select RAPT Bluetooth.
The RAPT Pill BLE integration will automatically discover devices once the Bluetooth integration is enabled and functional. RAPT Pill must be switched to the Bluetooth mode in Settings - Telemetry method. See the user manual for detailed instructions.
