Private BLE Device
Some BLE devices use a privacy feature called Resolvable Private Addresses to stop businesses from tracking you when you are out with your smart devices. Instead of having a single static address that can be used to track you, its Bluetooth address changes frequently. If you have Bluetooth enabled and functioning and know your device’s Identity Resolving Key, you can add it to Home Assistant as a Private BLE Device. We can then work out which random MAC addresses are related to the IRK and track those.
In addition to telling you if your device is home or away, it can also tell you an estimated distance to the nearest Bluetooth dongle or proxy and its signal strength.
To add the Private BLE Device integration to your Home Assistant instance, use this My button:
From the list, select Private BLE Device.
Your device must be on and broadcasting in range before adding it to Home Assistant - we check that it’s visible to validate that your IRK is correct.
There are two common representations for encoding an IRK - base64 encoding or hex encoding. This integration supports both.
Getting your Identity Resolving Key (IRK)
On macOS
If you are trying to get the IRK for your iPhone or Apple Watch, you must be logged in to the Mac with the same iCloud account on those devices. This procedure should also work for devices that you pair with macOS.
- Start the Keychain Access application.
- In the left sidebar, make sure iCloud is selected.
- In the search bar in the upper right, type Bluetooth.
- A list of GUIDs is shown.
- Double-click on a record. As part of the Account field, it will say
Public: XX:XX:XX:XX:XX:XX
. This MAC address should match the device you are trying to work with. - Click on show password
- You will have to enter your password, then enter your username and password.
- macOS will show some XML. You are looking for the “Remote IRK” field. After there is a data field that contains a base64 encoded version of your Identity Resolving Key.
On Windows / For Android
If you have a rooted Android phone, the IRK (and LTKs) can be viewed in the file /data/misc/bluedroid/bt_config.conf
. The LE_LOCAL_KEY_IRK specifies the Android device’s own IRK, and the first 16 bytes of LE_KEY_PID for every bonded device in the file indicate the bonded device’s IRK. Be aware that keys stored in this file are a little-endian, so the byte order of keys in this file will need to be reversed. For example, the little-endian IRK 22BC0E3F2EACF08EE36B865553EA0B4E needs to be changed to 4E0BEA5355866BE38EF0AC2E3F0EBC22.
Alternatively, the IRK of an Android phone and/or secondary device can be obtained using Wireshark:
- In developer settings on the Android phone, enable the “USB Debugging” and “Enable Bluetooth HCI snoop log” options.
- Ensure a second Bluetooth device (e.g., smartwatch or earbuds) is unpaired.
- Disable and re-enable Bluetooth on the phone ,then re-pair the secondary device.
- Connect the Android phone to a computer with adb
installed. - Establish an adb connection (
adb connect...
), then run the command:adb bugreport scanwatch
. - In the generated
scanwatch.zip
file, locate and extractFS\data\misc\bluetooth\logs\btsnoop_hci.log
. - Open
btsnoop_hci.log
in Wiresharkand search for btsmp.id_resolving_key
. - Select one of the frames and expand the “Bluetooth Security Manager Protocol.” The hex dump will show either the sending or receiving device IRK.
- Reverse the value displayed. For example, if it is
763af6c7f7d94ad6c262158e2320544e
, the IRK to use would be:4e5420238e1562c2d64ad9f7c7f63a76
On Windows - for any devices that will connect to a computer
- Get the PsExec tool from Microsoft. It’s available in the Sysinternals Suite
. Download and extract the PsExec.exe
orPsExec64.exe
. - Open Command Prompt as Administrator: Press the Windows key, type
cmd
, right-click on Command Prompt, and select Run as administrator. - Run PsExec: Navigate to the folder where PsExec is located and run
psexec -i -s cmd
orpsexec64 -i -s cmd
. This command will open a new command prompt window with SYSTEM rights. - Verify SYSTEM Rights: In the new command prompt window, type
whoami
to confirm that you have SYSTEM rights. - Open Registry Editor with SYSTEM Rights: In the new command prompt window, type
regedit
to open the Registry Editor with SYSTEM rights. - Locate the IRK: Navigate to
HKLM\SYSTEM\CurrentControlSet\Services\BTHPORT\Parameters\Keys
. There is one subfolder that probably holds the computer’s Bluetooth radio’s MAC address, look inside it for the folder corresponding to the MAC address of your Bluetooth device. - Right-click the key(folder) and select export. Save the
.reg
file somewhere. - Open the
.reg
file in Notepad. To open the Replace window, press Ctrl+H. Find what: “,” and Replace with “”. Select Replace All. This removes all commas from the hex value. - Copy the IRK value (only the part after
hex:
) and it can be used as-is. No reversing of byte order needs to be done.
ESPresense
If you already use Identity Resolving Key tracking with ESPresence then you already have a hex-encoded version of your Identity Resolving Key. Home Assistant can use the key in this format directly.
