NYT Games
The NYT Games integration fetches data about your progress on their daily puzzles.
Before setting up the integration, you need to fetch the token from the dev tools of your browser.
  1. On your computer, go to NYT Games.
  2. Login with your account.
  3. Open the developer tools via right-click or by pressing F12.
  4. Open the network tab and refresh the page.
  5. Select a request with .json in the name and go to the cookie tab.
  6. The token can be found in the NYT-S cookie.
To add the NYT Games service to your Home Assistant instance, use this My button:
  • From the list, select NYT Games.
