Om Luftkvalitet i Norge (Norway Air)
The norway_air
integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] queries
To add the air quality integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] to your installation, add the following to your configuration.yaml
If you want to get forecast data instead of the current data, set this to the number of hours that you want to look into the future.
Manually specify latitude.
Provided by Home Assistant configuration
