Nice G.O.
The Nice G.O. integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control Nice G.O. garage doors through Home Assistant. Device names in Home Assistant are generated based on the names defined in your Nice G.O. mobile app.
Make sure you have a working account with the Nice G.O. app and have your email and password ready.
To add the Nice G.O. integration to your Home Assistant instance, use this My button:
  • From the list, select Nice G.O..
Cover
Garage doors linked to your Nice G.O. account will appear as covers.
Event
The barrier obstructed event entity will be triggered whenever the barrier gets obstructed. This could be triggered by anything that results in the closure being unsuccessful. This may include beam block during closure, beam block before closure, and an object in the way.
Light
Lights on your garage door will appear as lights.
Switch
A switch for turning vacation mode on and off will be made available for each device. Vacation mode prevents the operation of the door from physical control points such as a wall station, wireless keypad, remote control, or HomeLink. It can still be controlled from Home Assistant.
