MQTT Statestream
The mqtt_statestream integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] publishes state changes in Home Assistant to individual MQTT topics. The MQTT integration is a prerequisite for MQTT Statestream to work.
To enable MQTT Statestream in Home Assistant, add the following section to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes.
mqtt_statestream:
  base_topic: homeassistant
  publish_attributes: true
  publish_timestamps: true
YAML
base_topic string Required
Base topic used to generate the actual topic used to publish.
publish_attributes boolean (Optional, default: false)
Publish attributes of the entity as well as the state.
publish_timestamps boolean (Optional, default: false)
Publish the last_changed and last_updated timestamps for the entity.
exclude list (Optional)
Configure which integrations should be excluded from recordings. (Configure Filter)
entities list (Optional)
The list of entity ids to be excluded from recordings.
entity_globs list (Optional)
Exclude all entities matching a listed pattern from recordings (e.g., sensor.weather_*).
domains list (Optional)
The list of domains to be excluded from recordings.
include list (Optional)
Configure which integrations should be included in recordings. If set, all other entities will not be recorded. (Configure Filter)
The list of entity ids to be included from recordings.
Include all entities matching a listed pattern in recordings (e.g., sensor.weather_*).
The list of domains to be included from recordings.
Configure filter
By default, no entity will be excluded. To limit which entities are being exposed to MQTT Statestream, you can use the include and exclude parameters.
# Example filter to include specified domains and exclude specified entities
mqtt_statestream:
  include:
    domains:
      - alarm_control_panel
      - light
    entity_globs:
      - binary_sensor.*_occupancy
  exclude:
    entities:
      - light.kitchen_light
YAML
Filters are applied as follows:
  1. No filter
    • All entities included
  2. Only includes
    • Entity listed in entities include: include
    • Otherwise, entity matches domain include: include
    • Otherwise, entity matches glob include: include
    • Otherwise: exclude
  3. Only excludes
    • Entity listed in exclude: exclude
    • Otherwise, entity matches domain exclude: exclude
    • Otherwise, entity matches glob exclude: exclude
    • Otherwise: include
  4. Domain and/or glob includes (may also have excludes)
    • Otherwise, entity listed in entities exclude: exclude
  5. Domain and/or glob excludes (no domain and/or glob includes)
    • Otherwise, entity listed in exclude: exclude
  6. No Domain and/or glob includes or excludes
The following characters can be used in entity globs:
* - The asterisk represents zero, one, or multiple characters ? - The question mark represents zero or one character
Common filtering examples
# Example of excluding entities
mqtt_statestream:
  exclude:
    domains:
      - switch
    entities:
      - sensor.nopublish
YAML
In the above example, all entities except for switch.x and sensor.nopublish will be published to MQTT.
mqtt_statestream:
  include:
    domains:
      - sensor
    entities:
      - lock.important
YAML
In this example, only sensor.x and lock.important will be published.
mqtt_statestream:
  include:
    domains:
      - sensor
  exclude:
    entities:
      - sensor.noshow
YAML
In this example, all sensors except for sensor.noshow will be published.
Operation
When any Home Assistant entity changes, this integration will publish that change to MQTT.
The topic for each entity is different, so you can easily subscribe other systems to just the entities you are interested in. The topic will be in the form base_topic/domain/entity/state.
For example, with the example configuration above, if an entity called ‘light.master_bedroom_dimmer’ is turned on, this integration will publish on to homeassistant/light/master_bedroom_dimmer/state.
If that entity also has an attribute called brightness, the integration will also publish the value of that attribute to homeassistant/light/master_bedroom_dimmer/brightness.
All states and attributes are passed through JSON serialization before publishing. Please note that this causes strings to be quoted (e.g., the string ‘on’ will be published as ‘“on”’). You can access the JSON deserialized values (as well as unquoted strings) at many places by using value_json instead of value.
The last_updated and last_changed values for the entity will be published to homeassistant/light/master_bedroom_dimmer/last_updated and homeassistant/light/master_bedroom_dimmer/last_changed, respectively. The timestamps are in ISO 8601 format - for example, 2017-10-01T23:20:30.920969+00:00.
