MQTT room presence
The mqtt_room
sensor integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to detect the indoor location of devices using MQTT clients.
To use this device tracker in your installation, add the following to your configuration.yaml
The time in seconds after which the state should be set to not_home
if there were no updates. 0
disables the check.
The time in seconds after which a room presence state is considered old. An example: device1 is reported at scanner1 with a distance of 1. No further updates are sent from scanner1. After 5 seconds scanner2 reports device1 with a distance of 2. The old location info is discarded in favor of the new scanner2 information as the timeout has passed.
Usage
Example JSON that should be published to the room topics:
Setting up clients
This integration works with any software that is sending data in the given format. Each client should post the discovered devices in its own subtopic of the configured topic. Instead of developing your own application, you can also use any of these already existing clients:
ESPresense
: Fork of ESP32-MQTT-room w/ fingerprinting, tile support, Kalman filter, based on C++/Platformio -
ESP-32-BLE-Scanner for Home Assistant
: ESP32 based BLE presence detection for Home Assistant with web GUI -
room-assistant
: looks for Bluetooth LE beacons, based on Node.js -
Happy Bubbles Presence Server
: presence detection server for Happy Bubbles BLE-scanning devices, based on Go -
ESP32-MQTT-room
: runs on an ESP32, and looks for Bluetooth LE devices, based on C++/Arduino -
OpenMQTTGateway
: uses ESP32 Bluetooth Low Energy to scan BLE Broadcaster like smart watches/bands and much more to get sensor values
