MQTT JSON
The mqtt_json
device tracker integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to detect presence by monitoring an MQTT topic for new locations. To use this platform, you specify a unique topic for each device.
To use this device tracker in your installation, add the following to your configuration.yaml
Usage
This platform receives JSON formatted payloads containing GPS information, for example:
Where longitude
is the longitude, latitude
is the latitude, gps_accuracy
is the accuracy in meters, battery_level
is the current battery level of the device sending the update.
longitude
and latitude
are required keys, gps_accuracy
and battery_level
are optional.
