Monarch Money
Monarch Money is a personal finance aggregation and budgeting service that integrates with Plaid, MX, and FinCity, the three major financial backends.
  • You need a Monarch Money account to use this integration.
  • You need account credentials. This integration supports both username and password login, as well as accounts configured with MFA.
To add the Monarch Money integration to your Home Assistant instance, use this My button:
  • From the list, select Monarch Money.
Accounts & devices
Each account is set up as a device in Home Assistant and contain the following sensors:
Sensor Description
Balance Account balance
Age This sensor shows when the data was retrieved by Monarch’s back end
