MINI Connected
Support for devices by MINI Connected in Home Assistant is provided by the BMW Connected Drive integration.
MINI Connected devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the BMW Connected Drive integration.
To add the MINI Connected integration to your Home Assistant instance, use this My button:
  • From the list, select MINI Connected.
Usage information
For more documentation on how to use MINI Connected in Home Assistant, please refer to the BMW Connected Drive integration documentation page.
