Linear Garage Door
Warning
This integration is now deprecated and will be removed in 2025.8.0. Please use the new Nice G.O. integration instead to avoid disruption.
For more information, refer to the Nice G.O. migration documentation.
The Linear integration lets you control Linear garage doors through Home Assistant. Device names in Home Assistant are generated based on the names defined in your Linear mobile app.
This integration is for garage doors connected to the cloud by Wi-Fi using the Linear mobile app.
To add the Linear Garage Door integration to your Home Assistant instance, use this My button:
  • From the list, select Linear Garage Door.
Cover
Garage doors linked to your Linear account will appear as covers.
Light
Lights on your garage door will appear as lights.
