Israel Railways
The Israel rail integration will give you the next three departure times from a given location to another one in Israel rail.
To add the Israel Railways integration to your Home Assistant instance, use this My button:
  • From the list, select Israel Railways.
The public timetables are coming from Israel rail.
Defining a custom polling interval
If you want to define a specific interval at which your device is being polled for data, you can disable the default polling interval and create your own polling automation.
To add the automation:
  1. Go to Settings > Devices & services, and select your integration.
  2. On the integration entry, select the .
    • Then, select System options and toggle the button to disable polling. Disable polling for updates
  3. To define your custom polling interval, create an automation.
  4. Save your new automation to poll for data.
