Improv via BLE
The Improv via BLE integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] sends your Wi-Fi network name and password to a Wi-Fi device over Bluetooth, so the device can join your Wi-Fi network. It works with Wi-Fi devices that support the open Improv via BLE standard, such as many devices with an ESP32 chip that run ESPHome. After the device is on your Wi-Fi network, it communicates with Home Assistant over Wi-Fi.
Difference between Improv via BLE devices and other Bluetooth devices
Improv via BLE devices and other Bluetooth devices both use Bluetooth, but in a different way:
- Improv via BLE devices are Wi-Fi devices. They use Bluetooth only once, to receive your Wi-Fi network name and password. After that, they communicate with Home Assistant over Wi-Fi, and you add them with their own integration, such as ESPHome.
- Other Bluetooth devices, such as BLE thermometers or plant sensors, send their data over Bluetooth all the time. They don’t join your Wi-Fi network and don’t use Improv via BLE. You add them with their own integration, such as Xiaomi BLE.
If your device supports Improv via BLE, Home Assistant shows it under Discovered as Improv via BLE while it isn’t connected to a Wi-Fi network yet.
- The Bluetooth integration must be set up and working, unless you use the Companion app.
- The Wi-Fi device supports Improv via BLE and isn’t connected to a Wi-Fi network yet.
- One of the following is within Bluetooth range of the Wi-Fi device. It sends your Wi-Fi details to the device:
- The Bluetooth adapter of your Home Assistant server.
- A Bluetooth proxy that supports active connections.
- Home Assistant needs a connection to the Wi-Fi device to send it your Wi-Fi details. An ESPHome Bluetooth proxy supports this. On ESP32 devices, active connections are turned on by default. Shelly and SMLIGHT proxies only listen to Bluetooth devices, so they can’t be used.
- Your phone with the Home Assistant Companion app, if the app has Bluetooth access.
- In the app, go to Settings > Devices & services. Wi-Fi devices that your phone finds show up under Discovered as Improv via BLE.
- When you start the setup in the app, the app sends the Wi-Fi details itself, even if Home Assistant also found the device.
- Have the name (SSID) and password of your Wi-Fi network ready.
- Most devices with an ESP32 chip only connect to 2.4 GHz Wi-Fi networks. Most routers provide a 2.4 GHz network by default. Often, it has the same name as the 5 GHz network. Usually, you don’t need to change anything.
To add the Improv via BLE device to your Home Assistant instance, use this My button:
Improv via BLE can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Improv via BLE.
If the device can identify itself, a menu opens first:
- To check which device you are setting up, select Identify device. The device blinks or beeps. Select Submit to return to the menu.
- To continue, select Connect device to a Wi-Fi network.
If the device asks for authorization, press the authorization button on the device. For details, refer to the manual of the device.
After the device has joined your Wi-Fi network, add it to Home Assistant with the integration for that device. For example, for a device that runs ESPHome, Discovered ESPHome device opens right away. To add the device, select Submit. Other devices show up under Discovered with their own integration, or show a link to their setup instructions.
Known limitations
- Improv via BLE only sends your Wi-Fi details to the Wi-Fi device.
- It doesn’t add the Wi-Fi device to Home Assistant, and it doesn’t show up in your list of integrations.
- You add the Wi-Fi device itself with its own integration, for example, ESPHome.
- Improv via BLE only works for Wi-Fi devices that aren’t connected to a Wi-Fi network yet.
- If Improv via BLE uses a Bluetooth proxy, the proxy must support active connections, such as an ESPHome proxy. Shelly and SMLIGHT proxies can’t make connections.
The Wi-Fi device can’t join your Wi-Fi network
Symptom: “The device could not connect to the Wi-Fi network”
After you enter your Wi-Fi details, the form shows the message “The device could not connect to the Wi-Fi network. Check that the SSID and password are correct and try again.”
Description
The Wi-Fi device received your Wi-Fi details, but it couldn’t join your Wi-Fi network with them.
Resolution
- Check that the SSID matches the name of your Wi-Fi network exactly, including uppercase and lowercase letters.
- Check the Password.
- Make sure your router provides a 2.4 GHz Wi-Fi network. Most devices with an ESP32 chip only connect to 2.4 GHz Wi-Fi networks.
- Make sure the Wi-Fi device is within range of your Wi-Fi network.
- Enter your Wi-Fi details again, and select Submit.
The setup stops with a message that the Wi-Fi device is already connected
Symptom: “The device is either already connected to Wi-Fi, or no longer able to connect to Wi-Fi”
During the setup, it stops with the message “The device is either already connected to Wi-Fi, or no longer able to connect to Wi-Fi. If you want to connect it to another network, try factory resetting it first.”
Description
The Wi-Fi device no longer accepts Wi-Fi details over Bluetooth. Usually, this is because it’s already connected to a Wi-Fi network.
Resolution
- If the Wi-Fi device is already on your Wi-Fi network, you don’t need Improv via BLE. Add the device with its own integration, for example, ESPHome.
- To connect the Wi-Fi device to a different Wi-Fi network, reset it to its factory settings first. For the steps, refer to the manual of the device. Then, set it up again.
The setup stops with the message Failed to connect
Symptom: “Failed to connect”
During the setup, it stops with the message “Failed to connect”.
Description
Home Assistant couldn’t make a Bluetooth connection to the Wi-Fi device. To send your Wi-Fi details, Home Assistant needs a connection to the device.
Resolution
- Move the Wi-Fi device closer to your Home Assistant server, or to an ESPHome Bluetooth proxy.
- If the only Bluetooth proxy within range is a Shelly or SMLIGHT proxy, use another way to send the Wi-Fi details. These proxies can’t make connections. For the options, refer to Prerequisites.
- Then, start the setup again.
A Wi-Fi device keeps showing up under Discovered
Symptom: The same Improv via BLE device keeps showing up under Discovered
A Wi-Fi device keeps showing up under Discovered as Improv via BLE, also after a restart of Home Assistant, and you don’t want to set it up.
Description
The Wi-Fi device isn’t connected to a Wi-Fi network, so it keeps announcing over Bluetooth that it supports Improv via BLE. For example, it’s a spare device, a neighbor’s device within Bluetooth range, or a device that lost its Wi-Fi network. As soon as a device is connected to Wi-Fi, it stops showing up under Discovered by itself.
Resolution
- Under Discovered, on the card of the Wi-Fi device, select Ignore.
- Result: Home Assistant no longer shows the device under Discovered.
There’s nothing to remove. Improv via BLE doesn’t keep an entry in your list of integrations, because it only sends your Wi-Fi details to the Wi-Fi device.
To remove a Wi-Fi device that you set up with Improv via BLE, remove it from its own integration, for example, ESPHome.
