IMGW-PIB
The IMGW-PIB integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] uses hydrological data from the Institute of Meteorology and Water Management - National Research Institute to present information about rivers and water reservoirs in Poland.
Use case: Monitor hydrological alerts to protect your family and property from floods, or track river water levels to gain long-term insight into climate change in your area.
To add the IMGW-PIB service to your Home Assistant instance, use this My button:
  • From the list, select IMGW-PIB.
Hydrological station
Select a hydrological station from the list of available stations.
Supported functionality
The IMGW-PIB integration provides the following entities.
Sensors
  • Water level
    • Description: Water level in the river or reservoir at the measurement point
  • Water flow
    • Description: River water flow at the measurement point
    • Remarks: Not available for all hydrological stations
  • Water temperature
    • Description: Water temperature in the river or reservoir at the measurement point
  • Hydrological alert
    • Description: Provides information on hydrological alerts for a given river or reservoir
  • Ice phenomena
    • Description: Ice phenomena sensor shows how much of the river surface is affected by ice, such as slush, ice floes, or a frozen cover
  • Emergent vegetation cover
    • Description: Emergent vegetation cover indicates how much of the river cross-section is occupied by plants that grow above the water surface
    • Remarks: Not available for all hydrological stations, disabled by default
  • Floating vegetation cover
    • Description: Floating vegetation cover indicates how much of the river cross-section is covered by plants floating on the water surface
  • Submerged vegetation cover
    • Description: Submerged vegetation cover indicates how much of the river cross-section is occupied by plants growing under the water surface
IMGW-PIB automation examples
The Hydrological alert sensor lets you react when a hydrological alert is detected for your river or reservoir. Here is an idea to get you started.
Tip
Automation: Create a hydrological alert notification
Use the Hydrological alert sensor to create a persistent notification with the content and probability of a hydrological alert. Replace the entity ID in the example with the entity ID of your station’s Hydrological alert sensor.
  • Trigger: State changed
    • Target: Your station’s Hydrological alert sensor
  • Action: Persistent Notification: Create persistent notification
    • Title: Hydrological alert!
    • Message: {{ trigger.to_state.state }}, probability {{ trigger.to_state.attributes.probability }}%
YAML example for creating a hydrological alert notification
alias: "Hydrological alert"
triggers:
  - trigger: state
    entity_id: sensor.warta_oborniki_hydrological_alert
actions:
  - action: persistent_notification.create
      title: "Hydrological alert!"
      message: >
Data updates
The IMGW-PIB integration pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] data from the IMGW-PIB API every 30 minutes by default.
Known limitations
  • The integration provides data for hydrological stations available through the public IMGW-PIB API. Some hydrological stations are not available in this data and therefore the integration does not support them.
  • Not all hydrological stations provide all data, so the set of entities for individual stations may differ.
The entities are unavailable
Symptom: The entities of the hydrological station become unavailable
The entities of the hydrological station show as unavailable, or Settings > System > Logs contains messages about connecting to the IMGW-PIB API or retrieving data from it.
Description
Home Assistant cannot reach the IMGW-PIB API, or the API does not return data for the selected hydrological station.
Resolution
  1. Check that Home Assistant has a working internet connection.
  2. Wait for the next data update. The integration retries automatically every 30 minutes, and the entities become available again when the IMGW-PIB API returns data.
      • Devices
      • Hubs
      • Services
      • Integration entries
  3. To confirm, select Delete.
