Image upload
The Image upload integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows Home Assistant to handle image assets in Home Assistant, for example, the profile photos of your systems account.
Uploaded images are also viewable in the media browser.
This integration is by default enabled, unless you’ve disabled or removed the
default_config:
line from your configuration.
If that is the case, the following example shows you how to enable this integration manually:
