HomematicIP Cloud
The HomematicIP
- Alarm
- Binary sensor
- Button
- Climate
- Cover
- Event
- Light
- Lock
- Sensor
- Switch
- Weather
To add the HomematicIP Cloud integration to your Home Assistant instance, use this My button:
From the list, select HomematicIP Cloud.
Generate the authentication token:
hmip_generate_auth_token.py
Add the information to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
Adding and removing devices and group via native HomematicIP APP
Devices and groups are instantly removed from Home Assistant when removed in the native HomematicIP APP. Groups are instantly created in Home Assistant when created in the native HomematicIP APP. Devices are created with a delay of 30 seconds in Home Assistant when created in the native HomematicIP APP. Within this delay the device registration should be completed in the App, otherwise the device name will be a default one based on the device type. This can easily be fixed in the Home Assistant entity registry afterwards.
Implemented and tested devices
homematicip_cloud.alarm_control_panel
- Combined Alarm Control Panal with INTERNAL and EXTERNAL Security zones (HmIP-SecurityZone)
homematicip_cloud.binary_sensor
- Access Point Cloud Connection (HmIP-HAP, HmIP-HAP-B1)
- Acceleration Sensor (HMIP-SAM)
- Inclination and vibration Sensor (HMIP-STV)
- Window and door contact (HmIP-SWDO, HmIP-SWDO-PL, HmIP-SWDO-I, HmIP-SWDM, HmIP-SWDM-B2)
- Contact Interface flush-mount – 1x channel (HmIP-FCI1)
- Contact Interface flush-mount – 6x channels (HmIP-FCI6)
- Contact Interface (HmIP-SCI)
- Window Rotary Handle Sensor (HmIP-SRH)
- Smoke sensor and alarm (HmIP-SWSD)
- Motion Detector with Brightness Sensor - indoor (HmIP-SMI)
- Motion Detector with Brightness Sensor - outdoor (HmIP-SMO)
- Presence Sensor – indoor (HmIP-SPI)
- Rain Sensor (HmIP-SRD)
- Water Sensor (HmIP-SWD)
- Remote Control - 8x buttons (HmIP-RC8) (battery only)
- Wall-mount Remote Control - 2x buttons (HmIP-WRC2) (battery only)
- Wall-mount Remote Control - flat - 2x buttons (HmIP-WRCC2) (battery only)
- Wall-mount Remote Control - 6x buttons (HmIP-WRC6) (battery only)
- Key Ring Remote Control - 4x buttons (HmIP-KRC4) (battery only)
- Key Ring Remote Control - alarm (HmIP-KRCA) (battery only)
- Alarm Siren (HmIP-ASIR, -B1) (battery only)
- Remote Control for brand switches – 2x buttons (HmIP-BRC2) (battery only)
- Pluggable Power Supply Monitoring (HmIP-PMFS)
- Wired Inbound module – 32x channels (HMIPW-DRI32)
homematicip_cloud.button
- Wall Mounted Garage Door Controller (HmIP-WGC)
homematicip_cloud.climate
- Climate group (HmIP-HeatingGroup)
- This includes temperature/humidity measures for climate devices of a room delivered by:
- Wall-mounted thermostat (HmIP-WTH, HmIP-WTH-2, HmIP-WTH-B)
- Brand Wall-mounted thermostat (HmIP-BWTH, HmIP-BWTH-24)
- Radiator thermostat (HmIP-eTRV, HmIP-eTRV-2, HmIP-eTRV-C) - should also work with (HmIP-eTRV-2-UK, HmIP-eTRV-2-B, HmIP-eTRV-2-B1)
- Temperature and humidity sensor (HmIP-STH)
- Temperature and humidity Sensor with display (HmIP-STHD)
- Alpha IP Wall Thermostat Display (ALPHA-IP-RBG)
- Alpha IP Wall Thermostat Display analog (ALPHA-IP-RBGa)
- There is no need to directly support the following devices by Home Assistant, because their integration is done by the required wall thermostats:
- Floor Heating Actuator – 6x channels, 230V (HMIP-FAL230-C6)
- Floor Heating Actuator – 10x channels, 230V (HMIP-FAL230-C10)
- Floor Heating Actuator – 6x channels, 24V (HMIP-FAL24-C6)
- Floor Heating Actuator – 10x channels, 24V (HMIP-FAL24-C10)
- Floor Heating Actuator – 12x channels, motorized (HMIP-FALMOT-C12)
homematicip_cloud.cover
- Shutter actuator for brand-mount (HmIP-BROLL)
- Shutter actuator for flush-mount (HmIP-FROLL)
- Blind Actuator for brand switches (HmIP-BBL)
- Blind Actuator for DIN rail mount – 4x channels (HMIP-DRBLI4)
- Blind Actuator for flush-mount (HmIP-FBL)
- Garage door module for Tormatic (HmIP-MOD_TM)
- Module for Hoermann drives (HMIP-MOD-HO)
- Hunter Douglas & erfal window blinds (HMIP-HDM1)
homematicip_cloud.event
- Doorbell Event for devices HmIP-DSD-PCB and others where ChannelRole equals DOOR_BELL_INPUT
homematicip_cloud.light
- Switch actuator and meter for brand switches (HmIP-BSM)
- Dimming actuator for brand switches (HmIP-BDT)
- Dimming actuator flush-mount (HmIP-FDT)
- Pluggable Dimmer – trailing edge (HmIP-PDT)
- Switch Actuator for brand switches – with signal lamp (HmIP-BSL)
- Wired Dimmer module – 3x channels (HMIPW-DRD3)
homematicip_cloud.lock
- Door Lock Drive - currently, usage just without a pin is possible (HmIP-DLD)
homematicip_cloud.sensor
- Access Point Duty Cycle (HmIP-HAP, HmIP-HAP-B1)
- Wall Mounted Thermostat (HmIP-WTH, HmIP-WTH2, HmIP-WTH-B)
- Temperature and Humidity Sensor without display - indoor (HmIP-STH)
- Temperature and Humidity Sensor with display - indoor (HmIP-STHD)
- Temperature and Humidity sensor - outdoor (HmIP-STHO, -A)
- Temperature sensor with external probes - 2-way (HmIP-STE2-PCB)
- Light Sensor - outdoor (HmIP-SLO)
- Passage Sensor with Direction Recognition (HmIP-SPDR) (delta counter)
- Floor Heating Actuator – 12x channels, motorized - Valve positions (HmIP-FALMOT-C12)
homematicip_cloud.switch
- Pluggable Switch (HmIP-PS)
- Pluggable Switch and Meter (HmIP-PSM) - should also work with (HmIP-PSM-CH, HmIP-PSM-IT, HmIP-PSM-UK, HmIP-PSM-PE)
- Switch Actuator and Meter – flush-mount (HmIP-FSM, HmIP-FSM16)
- Switch Actuator with Push-button Input – flush-mount (HmIP-FSI16)
- Open Collector Module Receiver - 8x channels (HmIP-MOD-OC8)
- Multi IO Box - 2x (HmIP-MIOB)
- Switch Circuit Board - 1x channels (HmIP-PCBS)
- Switch Circuit Board - 2x channels (HmIP-PCBS2)
- Printed Circuit Board Switch Battery (HmIP-PCBS-BAT)
- Switch Actuator for heating systems – 2x channels (HmIP-WHS2)
- Wired Switch Actuator – 8x channels (HMIPW-DRS8)
- Switch Actuator for DIN rail mount – 4x channels (HMIP-DRSI4)
- Switch Actuator for DIN rail mount – 1x channels (HMIP-DRSI1)
- Switch Actuator - 2x channels (HmIP-BS2)
homematicip_cloud.weather
- Weather Sensor – basic (HmIP-SWO-B)
- Weather Sensor – plus (HmIP-SWO-PL)
- Weather Sensor – pro (HmIP-SWO-PR)
What to do, if a device is missing in Home Assistant
In order for a device to be integrated into Home Assistant, it must first be implemented in the upstream library. A dump of your configuration is required for this, which is then attached to a new issue in the upstream lib’s
- Create a dump of your access point configuration in Home Assistant:
Developer Tools -> Actions -> Select
homematicip_cloud.dump_hap_config
-> Execute. The default dump is anonymized and is written to your configuration directory (hmip_config_XXXX.json
). - Create a new issue
at this GitHub repository and attach the created dump file.
Please be patient, wait for the implementation and a new release of the upstream library. Afterward, this device can be implemented into Home Assistant.
Actions
Executable by all users:
homematicip_cloud.activate_eco_mode_with_duration
: Activate eco mode with duration. -
homematicip_cloud.activate_eco_mode_with_period
: Activate eco mode with period. -
homematicip_cloud.activate_vacation
: Activates the vacation mode until the given time. -
homematicip_cloud.deactivate_eco_mode
: Deactivates the eco mode immediately. -
homematicip_cloud.deactivate_vacation
: Deactivates the vacation mode immediately. -
homematicip_cloud.set_active_climate_profile
: Set the active climate profile index. -
homematicip_cloud.set_home_cooling_mode
: Enable or disable cooling for the home.
Executable by administrators or within the context of an automation:
: Dump the configuration of the Homematic IP Access Point(s). -
homematicip_cloud.reset_energy_counter
: Reset energy counter of measuring actuators.
Action examples
accesspoint_id
(SGTIN) is optional for all actions and only relevant if you have multiple Homematic IP Accesspoints connected to HA. If empty, the action will be performed for all configured Homematic IP Access Points.
The accesspoint_id
(SGTIN) can be found on top of the integration page, or on the back of your Homematic IP Accesspoint.
The index of the climate profile is 1-based. You can get the required index from the native Homematic IP App.
Enable (or disable) Cooling mode for the entire home. Disabling Cooling mode will revert to Heating.
Additional info
Push button devices are only available with a battery sensor. This is due to a limitation of the vendor API (eq3). It’s not possible to detect a key press event on these devices at the moment.
- Wall-mount Remote Control for brand switches - 2x buttons (HmIP-BRC2)
- Motion Detector for 55mm frames - indoor (HmIP-SMI55)(Push button)
- Wall-mount Remote Control – flat (HmIP-WRCC2)
- Rotary Button (HmIP-WRCR)
