Home Assistant Alerts
The Home Assistant Alerts integration integrates the Home Assistant Alerts website into your Home Assistant instance.
This integration will pull in alerts put out by the Home Assistant team and will raise them in the Home Assistant Repairs dashboard if an alert is found that impacts your system.
This integration is by default enabled unless you’ve disabled or removed the default_config: line from your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file. If that is the case, the following example shows you how to enable this integration manually:
homeassistant_alerts:
YAML
