Google Sheets
The Google Sheets integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to connect your Google Drive to Home Assistant. The integration adds an action to allow you to append rows to a Sheets document. The idea is that you can store data on there for further processing. When you set up a config entry, your drive will have a new sheet called Home Assistant. You can then rename this to whatever you like.
Note: The integration currently only has access to that one document that is created during setup.
You need to configure developer credentials to allow Home Assistant to access your Google Account. These credentials are the same as the ones for Nest, YouTube, and Google Mail. These are not the same as Device Auth credentials previously recommended for Google Calendar.
Scenario 1: You already have credentials
In this case, all you need to do is enable the API:
  1. Go the Google Developers Console Google Drive API and Google Sheets API .
  2. Confirm the project and Enable the API.
  3. Continue with the steps described in the Configuration section.
Scenario 2: You do not have credentials set up yet
In this case, you need to generate a client secret first:
To generate client ID and client secret
This section explains how to generate a client ID and client secret on Google Developers Console.
  1. First, go to the Google Developers Console to enable Google Drive API and Google Sheets API .
  2. Select Create project, enter a project name and select Create.
  3. Enable the Google Drive API.
  4. Navigate to APIs & Services (left sidebar) > Credentials.
  5. In the left sidebar, select OAuth consent screen.
  6. It will take you to the Overview page and ask for Project Configuration:
    • Complete the App Information:
      • Set the App name (the name of the application asking for consent) to anything you want, for example, Home Assistant.
      • For a Support email, choose your email address from the dropdown menu.
      • Click Next.
    • For Audience, select External then click Next.
    • Under Contact Information, enter your email address (the same as above is fine). Click Next.
    • Read the policy and check the box if you agree. Click Continue.
    • Click Create.
  7. In the left sidebar, select Audience:
    • Under Publishing status > Testing, select Publish app.
      Otherwise, your credentials will expire every 7 days.
  8. In the left sidebar, select Clients:
    • Click + Create Client.
    • For Application type, choose Web Application and give this client ID a name (like “Home Assistant Client”).
    • Add https://my.home-assistant.io/redirect/oauth to Authorized redirect URIs then select Create.
      Note: This is not a placeholder. It is the URI that must be used.
  9. From the resulting dialog take a note of Client ID and Client Secret you can not retrieve it again after closing the dialog.
    • Once you have noted these strings, select Close.
    • Congratulations! You are now the keeper of a client secret. Guard it in your treasure box. In most cases, your new credentials will be active within a few minutes. However, Google states that activation may take up to five hours in some circumstances.
To add the Google Sheets service to your Home Assistant instance, use this My button:
  • From the list, select Google Sheets.
The integration setup will next give you instructions to enter the Application Credentials (OAuth Client ID and Client Secret) and authorize Home Assistant to connect to Google Sheets.
OAuth and device authorization steps
  1. Continue through the steps of selecting the account you want to authorize.
  2. NOTE: You may get a message telling you that the app has not been verified and you will need to acknowledge that in order to proceed.
  3. You can now see the details of what you are authorizing Home Assistant to access with two options at the bottom. Select Continue.
  4. The page will now display Link account to Home Assistant?, note Your instance URL. If this is not correct, refer to My Home Assistant. If everything looks good, select Link Account.
  5. You may close the window, and return back to Home Assistant where you should see a Success! message from Home Assistant.
If you have an error with your credentials you can delete them in the Application Credentials user interface.
Video tutorial
This video tutorial explains how to set up the Google Sheets integration and how you can add data from Home Assistant to a Google Sheet.
Action google_sheets.append_sheet
You can use the google_sheets.append_sheet action to add rows of data to the Sheets document created at setup.
Create event action details
Data attribute Optional Description Example
config_entry no Config entry to use.
worksheet yes Name of the worksheet. Defaults to the first one in the document. Sheet1
add_created_column yes Add created column containing date-time to the data being appended. Defaults to True. True
data no Data to be appended to the worksheet. This puts the data on new rows, one value per column. {“hello”: world, “cool”: True, “count”: 5}
# Example action
action: google_sheets.append_sheet
  config_entry: 1b4a46c6cba0677bbfb5a8c53e8618b0
  worksheet: "Car Charging"
  add_created_column: false
    Date: "{{ now().strftime('%-d-%b-%y') }}"
    KWh: "{{ states('input_number.car_charging_kwh')|float(0) }}"
    Cost: "{{ states('input_number.car_charging_cost')|float(0) }}"
# Example action with multiple rows
    - Item: "Car 1 cost"
      Cost: "{{ states('input_number.car_1_charging_cost')|float(0) }}"
    - Item: "Car 2 cost"
      Cost: "{{ states('input_number.car_2_charging_cost')|float(0) }}"
Action: Get sheet
You can use the google_sheets.get_sheet action to retrieve rows of data from a Sheets document.
rows no Maximum number of rows from the end of the worksheet to return. 2
# Example action
action: google_sheets.get_sheet
  rows: 2
Example action response
range:
  - - 04/07/2024
    - 9 Kw
  - - 05/07/2024
    - 8 Kw
