Google Pub/Sub
The google_pubsub
[Learn more] allows you to hook into the Home Assistant event bus and send events to Google Cloud Pub/Sub. The current free tier of GCP should allow you to sync about 1 event every 2 seconds on average (2 million invocations per month).
First time setup
This assumes you already have a Google Cloud project. If you don’t, please create one in the Google Cloud Console
Create a Google Pub/Sub topic in the Google Cloud API Console. The topic name will become something like projects/project-198373/topics/topic-name
. Note the last part only (the name you chose): topic-name
Next, you need to create a Service Account key in the Google Cloud API Console
- Choose a new “New Service Account”, give it a name and leave the key type as JSON
- Select the role: Pub/Sub Publisher
This will download the Service Account JSON key to your machine. Do NOT share this with anyone. Place this file in your Home Assistant configuration folder.
Add the following lines to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file, restart Home Assistant to apply the changes.
google_pubsub:
project_id: YOUR_PROJECT_ID
topic_name: YOUR_TOPIC_NAME
credentials_json: CREDENTIALS_FILENAME
The Pub/Sub relative topic name (looks like hass
Filter domains and entities for Google Cloud Pub/Sub. (Configure Filter)
Include all entities matching a listed pattern (e.g., sensor.weather_*
Exclude all entities matching a listed pattern (e.g., sensor.weather_*
Configure filter
By default, no entity will be excluded. To limit which entities are being exposed to Google Pub/Sub
, you can use the filter
parameter.
# Example filter to include specified domains and exclude specified entities
google_pubsub:
filter:
include_domains:
- alarm_control_panel
- light
include_entity_globs:
- binary_sensor.*_occupancy
exclude_entities:
- light.kitchen_light
Filters are applied as follows:
- No filter
- All entities included
- Only includes
- Entity listed in entities include: include
- Otherwise, entity matches domain include: include
- Otherwise, entity matches glob include: include
- Otherwise: exclude
- Only excludes
- Entity listed in exclude: exclude
- Otherwise, entity matches domain exclude: exclude
- Otherwise, entity matches glob exclude: exclude
- Otherwise: include
- Domain and/or glob includes (may also have excludes)
- Otherwise, entity listed in entities exclude: exclude
- Domain and/or glob excludes (no domain and/or glob includes)
- Otherwise, entity listed in exclude: exclude
- No Domain and/or glob includes or excludes
The following characters can be used in entity globs:
- The asterisk represents zero, one, or multiple characters
- The question mark represents zero or one character
Saving the data using a Google Cloud Function
To save your data automatically to BigQuery, follow the instructions here. The current free tier of GCP should allow to store up to 10GB of data.
