Google Cloud
The Google Cloud integration allows you to use Google Cloud Platform APIs and integrate them into Home Assistant.
To add the Google Cloud service to your Home Assistant instance, use this My button:
  • From the list, select Google Cloud.
Obtaining service account file
  1. Visit Cloud Resource Manager.
  2. Click CREATE PROJECT button at the top.
  3. Specify convenient Project name and click CREATE button.
  4. Make sure that billing is enabled for your Google Cloud Platform project.
  5. Enable needed Cloud API visiting one of the links below or APIs library, selecting your Project from the dropdown list and clicking the Continue button:
  6. Set up authentication:
    1. Visit this link
    2. From the toolbar above the Service account list, select Create service account.
    3. In the Service account name field, enter any name.
    If you are requesting a text-to-speech API key:
    1. Don’t select a value from the Role list. No role is required to access this service.
    2. Click Create. If a note appears, warning that this service account has no role, you may ignore that.
    3. Return to the Service account list page and click on the service account you created in step 5 to see the details for this service account.
    4. Choose the Keys tab within the details view for this service account.
    5. In the Add Key dropdown, select Create New Key.
    6. Specify a JSON key type and click Create.
    7. A [serviceaccountname].json file will download to your browser.
    8. Upload this file when asked in the integration setup.
Google Cloud text-to-speech
Google Cloud text-to-speech converts text into human-like speech in 380+ voices across 50+ languages and variants. It applies groundbreaking research in speech synthesis and Google’s powerful neural networks to deliver high-fidelity audio. With this easy-to-use API, you can create lifelike interactions with your users that transform customer service, device interaction, and other applications.
Pricing
The Cloud text-to-speech API is priced monthly based on the number of characters to synthesize into audio sent to the service. For up-to-date pricing, see here.
Text-to-speech configuration
Below settings can be configured in the options of the integration and in the options parameter of the tts.speak service.
language string (Optional, default: en-US)
Default language of the voice, e.g., en-US. Supported languages, genders and voices listed here. Also there are extra not documented but supported languages (see dropdown here).
gender string (Optional, default: neutral)
Default gender of the voice, e.g., male. Supported languages, genders and voices listed here.
voice string (Optional)
Default voice name, e.g., en-US-Wavenet-F. Supported languages, genders and voices listed here. Important! This parameter will override language and gender parameters if set.
encoding string (Optional, default: mp3)
Default audio encoder. Supported encodings are ogg_opus, mp3 and linear16.
speed float (Optional, default: 1.0)
Default rate/speed of the voice, in the range [0.25, 4.0]. 1.0 is the normal native speed supported by the specific voice. 2.0 is twice as fast, and 0.5 is half as fast. If unset(0.0), defaults to the native 1.0 speed.
pitch float (Optional, default: 0.0)
Default pitch of the voice, in the range [-20.0, 20.0]. 20 means increase of 20 semitones from the original pitch. -20 means decrease of 20 semitones from the original pitch.
gain float (Optional, default: 0.0)
Default volume gain (in dB) of the voice, in the range [-96.0, 16.0]. If unset, or set to a value of 0.0 (dB), will play at normal native signal amplitude. A value of -6.0 (dB) will play at approximately half the amplitude of the normal native signal amplitude. A value of +6.0 (dB) will play at approximately twice the amplitude of the normal native signal amplitude. Strongly recommend not to exceed +10 (dB) as there’s usually no effective increase in loudness for any value greater than that.
profiles list (Optional, default: [])
An identifier which selects ‘audio effects’ profiles that are applied on (post synthesized) text-to-speech. Effects are applied on top of each other in the order they are given. Supported profile ids listed here.
text_type string (Optional, default: text)
Default text type. Supported text types are text and ssml. Read more on what is that and how to use SSML here.
Action speak
The tts.speak action is the modern way to use Google Cloud TTS action. Add the speak action, select the entity for your Google Cloud TTS, select the media player entity or group to send the TTS audio to, and enter the message to speak.
For more options about speak, see the Speak section on the main TTS building block page.
A tts.speak service call can look like:
service: tts.speak
  entity_id: tts.google_cloud
  cache: true
  media_player_entity_id: media_player.living_room_display
  message: this is a test
  language: en-US
  options:
    gender: male
    voice: en-US-Wavenet-F
    encoding: linear16
    speed: 0.9
    pitch: -2.5
    gain: -5.0
    text_type: ssml
    profiles:
      - telephony-class-application
      - wearable-class-device
YAML
Action say (legacy)
The tts.google_cloud_say action can be used when configuring the legacy google_cloud text-to-speech platform in configuration.yaml. We recommend new users to instead set up the integration in the UI and use the tts.speak action with the corresponding Google Cloud text-to-speech entity as target. If you are an existing user of tts.google_cloud_say, you can still use it but don’t remove the legacy google_cloud text-to-speech platform in configuration.yaml. If you remove it, you will have to manually migrate to tts.speak.
Google Cloud speech-to-text
Google Cloud speech-to-text converts audio into text transcriptions for 125 languages and variants.
Pricing
Speech-to-text is priced based on the amount of audio successfully processed by the service each month, measured in increments of one second. For up-to-date pricing, see here under the Speech-to-text v1 API.
Speech-to-text configuration
stt_model string (Optional)
One of the transcription models here. Defaults to latest_short because this is the recommended one. If you get: 400 Invalid recognition 'config': The requested model is currently not supported for language : <language code> try changing this to the legacy command_and_search.
