FGLair
The FGLair integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides support for Fujitsu heat pumps and air conditioners that use the FGLair app.
To find out which app to use for your heat pump, check the Fujitsu FGLair FAQ
Supported devices
This integration supports a subset of devices that work with the FGlair app and other external integrations.
If your device name (visible in Settings > Firmware Information in the FGlair app) starts with AC-UTY, then your device is not supported by this integration.
Devices with names starting with AP-WA, AP-WB, AP-WC, AP-WD, or AP-WF should be supported.
First, set up your device in the FGLair app before using this integration. To configure this integration, you will need the credentials (login and password) used to connect to the FGLair application.
To add the FGLair integration to your Home Assistant instance, use this My button:
From the list, select FGLair.
Climate
This integration supports the following functionalities (if the devices support them):
Outside temperature
On units that support it, this integration will expose a temperature sensor that reports the outside temperature that the unit is sensing.
