ESERA 1-Wire
Support for devices by ESERA 1-Wire in Home Assistant is provided by the 1-Wire integration.
ESERA 1-Wire devices are either rebranded devices or devices that share a common communication protocol, making it possible to use them with the 1-Wire integration.
To add the ESERA 1-Wire integration to your Home Assistant instance, use this My button:
ESERA 1-Wire can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select ESERA 1-Wire.
Usage information
For more documentation on how to use ESERA 1-Wire in Home Assistant, please refer to the 1-Wire integration documentation page.
