Environment Canada
The Environment Canada integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides meteorological data for Canadian locations from Environment and Climate Change Canada
To add the Environment Canada integration to your Home Assistant instance, use this My button:
From the list, select Environment Canada.
Location selection
The integration automatically determines the closest weather station based on the latitude and longitude specified. If integration-specific coordinates are not provided, the coordinates configured for Home Assistant are used.
You can also specify a weather station to use by providing an identification code of the form AB/s0000123
, based on those listed in this CSV file
Entities
The integration will create the entities listed below. Some of the entities are disabled by default and can be enabled via the integration’s Entities page.
Weather
- Current conditions, daily forecast, and hourly forecast
Camera
- Loop of radar imagery from the last 3 hours (disabled by default). Also, by default, this entity uses the radar rain layer from 1 April to 30 November and the snow layer from 1 December to 31 March. The rain/snow layer can be changed using the action described below.
Sensors
Conditions and forecasts
- Current condition
- Forecast summary
Icon code
of current condition - Barometric pressure
- Pressure tendency
- Humidity
- Visibility
- UV index
- Air quality (AQHI)
Temperature
- Temperature
- Forecast high temperature
- Forecast low temperature
- Dewpoint
- Wind chill (only at temperatures below 0ºC)
- Humidex (only at temperatures above 19ºC)
Wind
- Wind speed
- Wind gust
- Wind direction
- Wind bearing
Precipitation
- Probability of precipitation
- Precipitation yesterday
Alerts
- Warnings
- Watches
- Advisories
- Statements
- Endings
The alert sensors use the number of current alerts as their state, with an attribute containing the title of each alert.
Solving problems
The Environment Canada service is very stable and provides high-quality data. Here are some steps that you can take before opening a problem report or posting on the forum.
Service interruptions
Although infrequent, there have been some outages and instabilities of the Environment Canada service. If you see error messages in your logs similar to the one below, it is very unlikely to be a problem with this integration and is likely a problem with the Environment Canada service.
The first course of action should be to check if there are known problems with the service. Look for recent messages on the Environment Canada mailing list
Sensor unavailable or unknown
Not all weather stations provide a complete set of weather/sensor data. The data that is retrieved by this integration can be found here
Template sensors
The configuration snippets below add template sensors. See the weather integration for additional examples.
Replace NAME
with the weather entity used in your configuration.
Feels Like
A sensor that takes into account the humidex or wind chill for what the temperature feels like.
Additional Forecast Data
The configuration snippet below adds a template sensor containing the current forecast information as attributes and the text summary of the forecast for the current day.
Actions
Action environment_canada.get_forecasts
Get the raw forecast data from Environment Canada. Returns both the daily_forecast
and the hourly_forecast
data.
entity_id |
yes | Weather entity to get forecast for. |
Action environment_canada.set_radar_type
Sets the type of radar to retrieve for the camera.
entity_id |
yes | Camera to set the radar type for. |
radar_type |
no | One of “Auto”, “Rain”, or “Snow”. |
