Energenie Power-Sockets
The Energenie Power-Sockets integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to include Energenie USB Power-Sockets into your Home Assistant setup.
To add the Energenie Power-Sockets integration to your Home Assistant instance, use this My button:
If you are running a Home Assistant CoreHome Assistant Core is the heart of Home Assistant itself. It is a Python program that powers every installation type, but can be installed standalone. [Learn more] or Home Assistant ContainerHome Assistant Container is a standalone container-based installation of Home Assistant Core. Any OCI compatible runtime can be used, but the documentation focus is on Docker.[Learn more] installation: Depending on your system configuration, it may be necessary to grant explicit user access rights to the USB device by creating an udev rule.
