Emoncms History
The emoncms_history
[Learn more] makes it possible to transfer (write) details collected with Home Assistant to Emoncms.org or your local running Emoncms instance. It will send the data to a specific input node on Emoncms with the entity IDs as a key. Afterwards you can create feeds and dashboards in Emoncms with the collected data.
To use the emoncms_history
[Learn more] in your installation, add the following to your configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.
[Learn more] file.
[Learn more] file, restart Home Assistant to apply the changes.
emoncms_history:
api_key: YOUR_EMONCMS_WRITE_API_KEY
url: https://emoncms.org
inputnode: 19
whitelist:
- sensor.owm_temperature
- sensor.owm_wind_speed
To read information from Emoncms to Home Assistant, you can use the emoncms
integration.
The base URL of Emoncms, use https://emoncms.org for the cloud-based version. For self-hosted Emoncms or EmonPi you may need a URL of http://x.x.x.x/emoncms
Input node that will be used inside Emoncms. Please make sure you use a dedicated, not used before, node for this integration!
